ls3 into ls1 car tune
i installed ls3 into oo z28 and did not change the reluctor on the crank can i get the ecm done to make this work do not what to remove motor and crank to fix this helpppppppppp.
Heres the harness. I read a post somewhere about the reluctor wheel issue although I cant recall if it was a yay or nay. Anyways bottom of this link is very basic info. Hope it helps
http://www.gmperformanceparts.com/SEMA/index.jsp
Yeah like I said I wasnt sure I just knew I read about it then just now I found that. It was described differently to me before but it should still work for him.
On another note you could just grab a compatible PCM and re work your harness and sensors to match. Its not that hard to re work these harnesses. A tune is definitely in order for that move though
You could probably make any PCM that came from a car/truck with the same count reluctor work. I'd try and source a PCM that will match your set up as close as possible for starters. Close as in an auto or manual and displacement probably a GTO or Vette. Then your work lies in sourcing info. You need to get the pin outs for your harness and your car and your engine if its different than the harness. Thats really the work there the splicing is cake. Heres a good place to start
https://ls1tech.com/forums/conversions-swaps/312119-ls1-swap-faqs.html
For what its worth I'm sure its been done do some searching and see who did it and how. Good luck
Anybody else know where to get this? I just had somebody call me yesterday with the same question. I wasn't aware of the external crank trigger option though, however I guess it would be the same as if you were going to use BS3 or something like that.
