98 to 02 cluster swap for fuel gage?
Who here has done the swap? I'm going to swap mine because i switched from a 98 to 02 ecm and cant get info on a fuel segment swap for hp tuners so i bought a 02 cluster and 02 fuel pump sending unit . Does anybody have the pin swap info for the cluster? Thanks for any help ahead of time.
I suggest just having someone with EFI Live set up the tune for you, EFI Live can do the segment swap.
If your not gonna do a custom OS, im pretty sure EFI Live could do the segment swap and VIN change in your new PCM and you should still be able to tune it with HP Tuners afterwords
