pcm controlling 4l80e
what type of programming would be required to control a 4l80e in my 98 ss. any help would be helpful , I understand I would need to rewire to change the wire harness to the trans- thanks,
Restricted User
Re: pcm controlling 4l80e
Kinda need to know this also. I konw they sell a controller, but I thought it was only for retrofit applications. Will be nice if the LS1/6 PCM can controll the 80E the right way.
i've heard about using a MVB in one and it takes the electronic control out of the picture. dont know if that holds up or not though, never done it. since that is basically a th400 w/ o/d i can see how it might work though.
I have the trans go manual shift in it but was wondering if I could figure out the pcm- I know for sure that it has been done but by a company that programs- so I don't think they will give out "the secret"
all the commands are the same but the wires are in different plugs. if you get wiring diagrams for both and switch the wires in the plugs it should work (havent tried it)
