View Poll Results: What MAF sensor is the BEST BANG FOR THE BUCK
Granatelli MAF
2
6.90%
Stock MAF
14
48.28%
SLP MAF
2
6.90%
AC DELCO 85mm
8
27.59%
other
3
10.34%
Voters: 29. You may not vote on this poll
What is the best MAF sensor?
Old 04-26-2008, 07:57 AM
suprsiz3_ls1's Avatar
Default What is the best MAF sensor?
SLP MAF
Granatelli MAF
Stock MAF
AC delco 85 MM MAF
Other
Old 04-26-2008, 09:35 AM
5301113's Avatar
Stocker can support up to 500hp and if you tune your car its better to have the stock one when tuning it.But then again with your mods AC delco 85mm is the way to go.
Old 04-26-2008, 09:56 AM
thats what I was Thinking, at least I would think the ac delco will allow more flow
Old 04-26-2008, 05:44 PM
macca_779's Avatar
The best MAF is no MAF at all. We upgrade MAF's to lower the restriction they impose. Why not just remove the restriction all together...
Old 04-27-2008, 09:22 AM
thanks for your help, I'm really thankful that everyone takes their time to answer my questions.
Old 04-27-2008, 09:37 AM
Frost's Avatar
If you change your MAF, you need to have the car tuned.
Old 04-27-2008, 09:43 AM
dreamls1's Avatar
what do you need to do to remove the MAF?
Old 04-27-2008, 09:47 AM
fast377's Avatar
Do a custom speed density tune.
Old 04-27-2008, 12:38 PM
Bill Bowling's Avatar
I have been running without a MAF for a couple of years or more.
Bill
Old 04-27-2008, 04:16 PM
what do you have to rig up to enable your car to run without a maf???
Old 04-27-2008, 04:32 PM
Frost's Avatar
gotta rig up one of them thar speed density toonz
Old 04-27-2008, 04:39 PM
99blancoSS's Avatar
nothng wrong with your stock MAF. I your looking to go bigger than get the OEM 85 /Delco.
Old 04-27-2008, 04:54 PM
You have to have your car tuned Speed Density. Do you have EFILive or HPTuners?
Bill
Old 04-27-2008, 05:34 PM
99blancoSS's Avatar
You could give him some more info than that on the SD..lol
You need to know what your doing or have it done for you.
SD vs MAF is a major battle on here, I'm not taking sides.
You could ruin your engine if you dont know what your doing very easily.
If your worried about restriction Texas Speed has a 100mm MAF (4") that you wont out flow in your application. Its a very nice unit.
Old 04-27-2008, 05:45 PM
YellowToy/A's Avatar
85 mm truck MAF from ebay. Cost about 65$ take the screen off free. Smooth out rough edges for better flow 45 mins and sand paper. Tune an hour for me. If you dont tune see ^ above.
Old 04-28-2008, 07:00 AM
DRGnFLYZ28's Avatar
You also have the option to run poly MAF ends. I had them on my 99 Z and it loved them. Tried them on my 02 and it ran like crap at idle... screamed up top. I removed it though. My stocker with no screen is just fine for my application.
Old 04-28-2008, 02:33 PM
Thanks for all the info
Old 04-29-2008, 06:12 PM
ssdriver27's Avatar
sorry but Im not convinced the stock is the way to go with the infamous MAF phenominon. I have both the stock screaned, and a ported MAF which has been ported to the MAX. its been ported so much the rubber seals are barely staying in its crazy ported. anyhow Im stumpped on the tunning of this POS but Im still running it over the stock screaned one, because my turbo spools so much faster its rediculous and the top end power is extremely noticeable. example in 4th gear with the ported MAF role on the throttle and she lights the tires up over 80 mph. stock MAF it slowly spools the turbo and barely lights up the tires in 3rd if at all. however its all over the board when it comes to just driving around. so not to step on someone elses thread Im just not convinced with the stock being the best way to go. ~Guy
ps: any help with tuning this highly ported MAF would be appreciated. Ive read almost every thread in here on MAFs and I dont feel I have a real understanding yet.
Old 04-29-2008, 09:24 PM
Frost's Avatar
If you have a turbo you are better off without ANY MAF and running a proper 2 or 3 bar SD tune if you are in the range of 7+ psi as you will be maxing it out anyway.
Old 04-30-2008, 11:24 AM
AlexLs1's Avatar
Stock MAF with heads, cam and N2O. Speed Density tune I might add.
Quick Reply: What is the best MAF sensor?
