Need assistence with base E85
i plan to run my setup on E85. I have motron #60s. fuel system is returnstyle. I was wondering if anyone could help me out on setting up my base tune so i can least fire. I did a search and didnt find exactly what i needed. im not asking for someone to tune my ride just lend some advice to point me in right direction
bascially which tables need adjusted and how for the E85, setup will also be using meth if that means anything. combo is 8.8cr 4.8, ported fast, PT88, 230/235 .598/.601 115+1, fed with -8 return with -6. using twin 340s. 3 bar map
I have Hptuners and will be using a 3bar SD tune
thanks in advance
thanks in advance
thanks in advance
thanks in advance
Air/Fuel Ratios
Fuel Stoich Rich Limit Lean Limit
Gasoline 14.7.1 12.5.1 13.2.1
Methanol 6.4.1 5.4.1 5.7.1
Ethanol 9.0.1 6.4.1 7.8.1
E-85 9.7.1 6.9.1 8.4.1
thanks in advance
thanks in advance
now i thought the 4.8 with the 60s and E85 would be enough for now. i have a 15.2 spring and was only going run off spring for now. i do have a boost controller for later and planned to upgrade to much larger injectors when 408 is in the vehicle
Assuming your trims are ok on gas,
Set your AFR to 10. (ball park). Log some trims. Average the trims, adjust your AFR by that amount (averaged).
Before people jump my case for this method, keep in mind not all E85 is created equal. E85 is deinfed by a MINIMUM of 15% gasoline, and it varies from station to station, batch to batch. Just get it in the ballpark.
Once your AFR is set to within reason, tune it like anything else. Play with timing (E85 loves it) and in cold weather you may need some more cranking fuel as ethanol doesn't evaporate as easily as gas.
