OLSD idling help
Old 09-21-2008, 03:14 PM
Reject's Avatar
Default OLSD idling help
alright i've been playing with the tune a little, just to get the idle to be correct (i'm going to let the shop do the WOT and all that other junk) anyways on my wideband the idle always stays around 11.2:1 i've messed around with the VE to see if it would change or anything but it constantly stays at that AFR.
the car has 60 pound injectors and i got on HPT website to compaire my numbers (just for the injectors) against country boy's file (he also had 60 pound injectors) both of our numbers were the same, again ONLY used his to compare my injector scaling numbers.
my VE is my stock VE up to 105kPa with a stock cam.... so i was thinking it should all pretty much be correct?
anyways could someone look over the file and see if i'm missing something?
thanks in advance!!
http://reject.sleepingz.com/HPT/CARR...TARTER%201.hpt
Old 09-21-2008, 10:36 PM
LS1Tech Sponsor
Slowhawk's Avatar
Lower the minimum injector pulse tables.
Old 09-22-2008, 08:05 AM
Reject's Avatar
i see the table your talking about, should i just adjust the 400-800 table (which are at 1.277) by like .95% ?
i was lowering the flow rate vs KPA just to see if the 11.2:1 would change, nothing happend. i think the sensor may be messed up? go LC1 yay!
Old 09-22-2008, 09:24 AM
edcmat-l1's Avatar
As Don stated, you have to lower the min ipw. At the stock settings, the 60s just deliver way too much fuel.
Old 09-22-2008, 12:09 PM
Reject's Avatar
i had lowered the min IPW all the way down to .091 and the AFR stayed around 11.2:1
i put a new sensor on and recalibrated it and everything. i know the sensor works becuase i tested it out and everything with the butan like the troubleshooting papers say to try, it passed.
so i copied over country boy's injector stuff and now the idle AFR is around 11.8:1 so it's going in the right direction now...... but that's as far as it will go
let me upload the newer file right wuick
Old 09-22-2008, 12:12 PM
Reject's Avatar
here we go
http://reject.sleepingz.com/HPT/CARR...0with%20CB.hpt
Old 09-22-2008, 12:41 PM
edcmat-l1's Avatar
Log the injector pulse width on your scanner. Post the log.
Old 09-23-2008, 06:30 AM
Reject's Avatar
will do! it'll be around noon or after work though today. thanks for the help so far!!
Old 09-23-2008, 06:04 PM
Reject's Avatar
alright here is the IFR scan
for the LC1
([PID.2811]/0.6100)+10
Sensor : Air Fuel Ratio
Units : afr
http://reject.sleepingz.com/HPT/IFR%...Inj%20file.hpl
Old 09-23-2008, 06:14 PM
Souless's Avatar
What PCM OS are you running or what year is your car? Also what tables are you adjusting the VE's? If so and you see a secondary VE table try adjust the secondary table if you are tuning with the MAF unplugged.
Old 09-23-2008, 06:37 PM
Reject's Avatar
car is a 2000 camaro, used to be with the primary and secondary VE table's but once you switch over to a 2Bar it just gives you the primary VE, also i dont have a MAF, sold it to some guy and it's on the other side of the country now
the VE tables i havnt touched as it's all basically a stock car minus the turbo and 60 pound injectors
Old 09-24-2008, 09:39 PM
Reject's Avatar
anything?
Old 09-25-2008, 01:36 PM
turbo'd stang's Avatar
I would mess with the VE table.
Old 09-25-2008, 01:41 PM
Reject's Avatar
but the only thing different is the injectors now, would the VE still need change?
Old 09-26-2008, 07:05 AM
Yeah, not unless you want to tune it through the injectors, the VE is THE table for A/F changes.
Old 09-28-2008, 11:37 AM
Souless's Avatar
yep, if you are having issues with A/F, and you entered the Inj flow rate numbers correctly then the only thing left to tweak is the VE table. Since you upgraded OS's then just make adjustments to the primary table. I would only make about 5% adjustments at a time until you get it right. Also remember that the car will act differently when the motor is cold vs being warmed up. It may read lean at first then richen up after some time.
Old 09-28-2008, 02:09 PM
Reject's Avatar
on the injector setting is everything good then? i was playing around with the car today, and like the rest of the VE table i can get to go where i want it to. but the idle part keeps staying rich
Old 09-28-2008, 04:16 PM
Frost's Avatar
You are at 2.3mS at idle; want to get that to about 1.9-2.0. I have good luck with the 60s at 1.9 on stock cars with power adders.
The VE is not what is wrong here. Log and notice that even after reducing VE, you minimum pulse width at idle is still at 2.3ish.
You need to adjust the the min pulse tables and adders appropriately.
Old 09-28-2008, 05:49 PM
edcmat-l1's Avatar
CARRIE STOCK 2BAR CONVERT FILE With FI SDSTARTER 1 with CB.EH.1.hpt
Try this one.
Old 09-28-2008, 06:07 PM
Reject's Avatar
im heading to a car meet but when i return i will load that file and update you. i will log idc and ipw, anything else you would like to see logged
