4.3L TT Swap
Old 12-05-2008, 07:36 PM
da96bird's Avatar
Default 4.3L TT Swap
I have a '96 3800 Firebird with about 135,000 miles on.....This spring I want to swap the 3800 out for a 4.3L V6 and throw 2 turbos on it...I need to know if this has ever been done before and if it is at all possible, and what exactly would be involved....personally, i've never seen this done before, and I want something that no one would expect......thanks for the help
Old 12-05-2008, 08:31 PM
WS.666's Avatar
What is the 4.3L out of?
Old 12-06-2008, 12:32 PM
da96bird's Avatar
you could get it out of a s-10 blazer sonoma an astro van
Old 12-06-2008, 06:21 PM
da96bird's Avatar
or should I just supercharge it and throw some juice on it?
Old 12-06-2008, 09:22 PM
Verz's Avatar
just turbo the 3800, is a 9.4:1 ratio so it has some room to put some boost to it.
Old 12-11-2008, 11:50 AM
90Accord's Avatar
i would swap out the 3800 for one out of a gtp poncho or at least get the s/c off of it, those 4.3's leave a really bad taste in my mouth
Old 12-24-2008, 12:04 AM
rat rod camaro's Avatar
There's nothing wrong with a turbo 4.3. GMC Syclones kick ***, but I don't know if the intake for one of those will fit in a 4th gen
Old 12-24-2008, 02:01 AM
Drumer919's Avatar
Sure its possible, anything is. Its not going to be easy, your not just going to be able to bolt it up "cause it use regular small block mounts" like Bubba told you, you better be able to fabricate parts.
Old 12-24-2008, 08:31 AM
1 Bad Ass Formula's Avatar
You're probably best off to turbo or supercharge the 3.8. The 3.8 is one of the best motors GM ever made, the series II 3.8 had a S/C on the 97-03 GP GTP's. Also the 3.8 in the F-Bodies is just a newer version of the one used in the Buick GN's. So I'd personally keep the 3.8 unless you do an LT1 or LS1 swap.
Old 12-24-2008, 09:02 AM
3.8SFITURBO's Avatar
How about an LC2 swap? Find a complete GN motor & trans and swap that in. A guy our GN club has a firebird he did the swap in, It's not that bad to do...
Old 01-08-2009, 10:46 AM
CRAZY21282's Avatar
I like the 4.3 idea. I HAVE A 4.3 in my 91' S-10 and it still roasts the 33's. A freash 4.3 with two turbos will kick ***
Quick Reply: 4.3L TT Swap
