how does the top of center console come off?
Old 03-10-2009, 08:34 AM
blackpontiacs's Avatar
Default how does the top of center console come off?
just wondering if there's anything i need to unhook before i take it off. looks like it just pops off but wanted to be sure. do i need to do anything with the ashtray or the cig lighter before i go popping it off? also what about the little cubby hole next to the lighter?
any help is appreciated! thanks.
edit: to be more specific - the part that goes from the dash to just in front of the storage area.
Old 03-10-2009, 10:21 AM
LS1W66's Avatar
Theres a light socket for the Ash tray and automatic trans selector (if equipped) and the cig Lighter. After that it just lifts out once the change holder and the bolts are removed.
Old 03-10-2009, 12:13 PM
nytmare1's Avatar
Lift out the coin holder in the utility box under the arm rest. Remove the two screws under the coin holder. If you have an A4, remove the "U" shaped pin on the front of the gear shift handle (pull out with a small screwdriver or needle nose pliers) and lift the handle off. You may want to put the gear shift in drive or somewhere close to that first. Lift the console up and back, then wiggle it off the gear shift post. Remove the gear indicator light wire and the cigaretter lighter wire and you're done.
If you have an M6, I don't know how to get the console around the boot so you're screwed. I'm guessing you just have to unscrew the handle, but what do I know...
Old 03-11-2009, 08:35 AM
Default center console
it is an a4, but really i'm just talking about the very top, it is a separate piece at from messing with it a little it looks like it should just pop out. i don't need to removed the whole center console. i guess i should have explained myself a little better.
Old 03-11-2009, 08:51 AM
Aetos's Avatar
M6 is even easier, the boot is clipped onto the console. All you have to do extra is unscrew the shifter **** instead of removing the U shaped pin. Everything else is the same.
Old 03-11-2009, 09:54 PM
nytmare1's Avatar
What storage area are you talking about? The little cubby under the dash and in front of the ashtray? Or the compartment where you keep CDs and other stuff (your elbow rests on it while driving)?
Old 03-12-2009, 08:33 AM
i don't need to remove the part your elbow rests on. just the plastic trim around the shifter.
Old 03-12-2009, 10:45 AM
Aetos's Avatar
You unscrew the 2 bolts under the coin holder inside of the armrest compartment. Undo the shifter with the uclip mentioned above, slowly pull the center console up and unplug the ashtray lightbuild, the tcs component(if installed) and acc harness.
Old 03-12-2009, 05:15 PM
nytmare1's Avatar
Ok... then follow the directions I gave above and also what Aetos said.
Old 03-12-2009, 08:40 PM
Rancor352's Avatar
Yep, just 2 7mm bolts under the coin holder and then it just pops off.
Old 03-12-2009, 09:51 PM
Swiat34's Avatar
JUST so we're clear, taking these screws out it needed to get the TOP PIECE only which you are trying to remove. If you're still confused, get a 7mm bit for a nut driver and just go do it! lol Not hard at all. It's easier if your shifter is in the "1" position.
Swat
Quick Reply: how does the top of center console come off?
