No RPO stickers... Can someone run a VIS
Hi Guys,
Got a WS-6 that no longer has Door or Glove Box RPO stickers.. Can someone run a VIS report...
2G2FV22P9T2217085
Thanks in advance..
2G2FV22P9T2217085
Thanks in advance..
'Bird Director
If the dealership he works at hasn't closed yet, you can get this info from chevymec. He has been very helpful to me on several occassions, but told me his dealership was closing soon with my last request.
https://ls1tech.com/forums/member.php?u=25136
Option codes
aaa - std safety/security features: * driver and passenger airbags * 4-wheel anti-lock brakes- w/ 4 wheel power disc brakes * pass-key ii anti-theft system * rear 3-point safety belts
ah3 - seat adjuster-manual 4 way driv
ak5 - driver & passenger side airbag
aq9 - articulating seat w/ cloth trim
au0 - remote keyless entry
au3 - power door locks
a31 - power windows
b35 - mats, carpet rear floor
b84 - body color body side moldings
cc1 - locking hatch roof, removable
c49 - defogger, elec rear window
c60 - air conditioning, custom
de4 - hatch roof sunshades, removable
dg7 - mirrors, sport lh/rh power
dl5 - decal roadside service
fe2 - suspension system, handling
fe9 - 50-state emissions
gu5 - rear perform axle, 3.23 ratio
g80 - differential, limited slip
il2 - trim interior design
j65 - brakes, pwr 4-whl,disc frt & rr
kg9 - generator, 140 amp
k34 - cruise control, resume speed
lt1 - 5.7 liter sfi v8 engine
mx0 - transmission, 4-speed automatic
m30 - automatic transmission
nf2 - federal emissions - tier 1
ng5 - 50-state emissions
np5 - steering wheel, leather wrapped w/leather wrapped shift ****
n66 - wheels, 17" cast aluminum
pbt - temp. Whl & tire-upfitter dlvy
qfk - tires, p275/40zr17 speed rated
r7n - p. C. N.
R8v - control-sales item #71
ste - asm plt st. Therese
t43 - spoiler, rear deck lid
t96 - lamps, fog
ua6 - content theft alarm
ub3 - rally gages w/tachometer
uk3 - steering wheel radio controls with leather appointment group
u75 - power antenna, automatic
vm3 - bumper std impact 5 mph frt &rr
v73 - vehicle certification u.s.
Ws6 - ram air perform.& handling pkg: * ram air induction system * functional air scoops * 5-spoke 17" aluminum wheels * p275/40zr17 speed rated tires * dual oval exhaust outlets * specific tuned suspension
ws9 - formula option
w54 - radio etr am/fm stereo w/auto reverse cassette graphic equalizer incl. Clock, seek up/down remote cd pre-wiring 10 speaker sound system
y82 - trans am option
1sa - option group - 1sa
12i - trim, graphite
122 - trim, graphite leather
6ab - component frt lh comput sel sus
7ab - component frt rh comput sel sus
8hs - component rr lh comput sel susp
81q - molding bright red
81u - paint, bright red
9hs - component rr rh comput sel susp
a31 - power windows
r7n - p. C. N.
t96 - lamps, fog
Is there anyway possible to extract the RPO listings for all 4-th gen f-bodies' VINs off of GMVIS? It would be REALLY COOL if there was a way to write a script that would load a sequence of VIN#s into GMVIS and download the RPO listing and write it to a database (essentially extract a copy of the GMVIS database). Could you imagine the level of detail of production # breakdowns that could be created with that data???
Interesting...
But good luck getting the data. This technique sounds like a red flag before it runs completely.
If it were possible, we will all have cars that are "rare" 1 of 3 produced because of some obscure option combination such as: CD changer, cassette deck, no cruise control, V6, 5 speed.
