Bulb is drivin me nuts (front passenger) Help
Old 05-02-2010, 11:36 PM
jaysan's Avatar
Default Bulb is drivin me nuts (front passenger) Help
I just replaced it two days ago and now it doesn't work. It is the front turn signal . I housing is good , the connection looks corroded (fixed it with coke) and when I turn on my lights the bulb lights up. But it won't flash when I use the turn signal. any thoughts ?
jaysan's Avatar
the bulb is still good too *
Old 05-03-2010, 01:49 AM
mannyman84's Avatar
on some cars if one turn signal is out all wont work.. Example: left marker out= left blinker out front and rear. rear blinker out= side blink marker and front blinker wont work, ect, ect make sure all the left or right side (which ever it is) bulbs are good
Old 05-03-2010, 02:07 AM
ls1ya's Avatar
i have had the same problem for some time now it won't flash or stay lit while running. but it works.
Old 05-03-2010, 11:56 AM
brutalis's Avatar
I had the same problem, just fixed it this weekend. I saw that the housing was corroded, so I started to clean it, but then I noticed that not only was it corroded, but there was a contact point missing. I replaced the housing ($8 at autozone) and the bulb, and everything works great now.
Old 05-04-2010, 01:05 PM
stockwellsm's Avatar
Post Same issues
Yeah, had the same problem after I screwed with it for a while and came on here, then I replaced the blub. Well If you shove it too far in you can have a problem like mine were it will stay lit constantly (not blinking). I loosened the light so it was comfortable in the light connection and not shoved into it and it worked fine.
Old 05-04-2010, 01:44 PM
twelver12's Avatar
The plug is corroded because the housing is leaking it happens to all of us
I replaced both of my housings and one socket and they are a lot brighter and work every time now and stay dry inside
Old 05-13-2010, 12:15 PM
TAtoad's Avatar
disconnect your battery, take the lightbulb out of the socket. get that **** girls use to remove they're nail paint, and a Q-tip. dip the q-tip in that liquid, and clean out the inside of the socket. i used to replace light bulbs every few months. haven't had a problem since october.
Old 05-13-2010, 12:50 PM
'Trust''s Avatar
Happened to 2 out of the 3 T/A's I've had. I would just replace the socket and be done with it.
Old 05-13-2010, 03:33 PM
Super-Bat's Avatar
Bring it to me man, I'll fix it for ya!
Old 05-17-2010, 10:19 PM
conde'strans's Avatar
X2! I did the same, got them from ebay and never had the problem again. Same exact problem the housing was leaking and corroding it.
Old 06-01-2010, 05:30 PM
angry's Avatar
Use an O-ring pick and scrape the corrosion out of the socket.
Put dielectric grease in the socket.
The dielectric grease works, my bulbs have been in for two years now.
Old 06-01-2010, 06:24 PM
NOS4EVER's Avatar
The is the best and most efficient solution what ever you do it's still corroded
And the problem will still come back.
Old 06-01-2010, 07:02 PM
98 Vicious LS1's Avatar
Where in the world did you get a housing for $8 I have been trying forever to find one, Autozone, Discount, Advance, Napa all don't have it or they are close to 40.00. 78 if you get it from GM. Please o please let me know that is not a misprint...
Old 06-01-2010, 07:16 PM
So far I cannot find a socket for the lights that is below 40.00. I refuse to pay that much without at least trying to afro engineer the problem.
Neither of my lights were working. So I pulled one socket and housing. Attached are the pictures of what I found. You can see the clear housing is in rather bad shape. I already ordered new ones ($20 per on eBay)(photos: 0560,0561,0562)
Went to Autozone, bought the $5 can of electric connector cleaner and $4 can of grease. Went to town with the cleaner and a handful of q-tips. I know its no substitute for a new socket but o well. (Photo: 0565)
I had to use a piece of .005 brass shim stock for the passenger side because the connector was so badly corroded it wasn't hitting.
They both work now. (Photo: 0567)
Like I said i know its a temp fix...
So total investment $20 (includes bulbs and q-tips)
Attached Thumbnails Bulb is drivin me nuts (front passenger) Help-img_0565.jpg   Bulb is drivin me nuts (front passenger) Help-img_0562.jpg   Bulb is drivin me nuts (front passenger) Help-img_0561.jpg   Bulb is drivin me nuts (front passenger) Help-img_0560.jpg   Bulb is drivin me nuts (front passenger) Help-img_0567.jpg
Old 06-01-2010, 07:30 PM
NOS4EVER's Avatar
40 $ or pulled over by the cops?
She gave you a lot so she deserve more
Nice ride
Old 06-01-2010, 07:51 PM
Nice ride
agreed, just this past weekend she happened to need new A/C, brake pads, rotors, tint and exhaust bracket.
This next paycheck is the taillamp housing and sockets...
Old 06-01-2010, 08:21 PM
jaysan's Avatar
I bought another socket and rebuilt it and then returned the old one . I was able to fool vato zone https://ls1tech.com/forums/general-m...signals-2.html
Old 06-01-2010, 09:22 PM
peterlawl84's Avatar
the socket can be found at autozone for like 8 bucks, Dorman P/n 85881.
No need to splice wires, just replace the socket (clean off the wire terminals when you remove the old socket).
Old 06-01-2010, 11:14 PM
Roxas's Avatar
How do you remove the old socket without splicing the wires? I got two of the dorman 85881's in my trunk, just waiting to install them. I looked over the old socket and thought that I'd have to splice the new sockets in.
Quick Reply: Bulb is drivin me nuts (front passenger) Help
