My attempt at a Shaker (project still in progress)
Old 07-08-2010, 06:55 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
Good progress so far!
I believe the now defunct Big 3 Performance was the shop that did the CETA with a shaker as well. I saw the car at the 2009 T/A Nationals.
Old 07-08-2010, 08:34 PM
1CAMWNDR's Avatar
That's just badass. I think it would look killer with a wide flat black stipe up the middle like the early Blue and White 70's Trans Ams.
What year is that scoop? 1970-1975? I think that was the smooth rounded one. I think 1976-1981 were the more angular one with the raised spine in the middle.
Old 07-09-2010, 09:16 AM
white2001formula's Avatar
I have considered mocking up a stripe with cheap vinyl to see how it looks. I originally wanted the light blue stripe, but not sure about it yet.
I "think" it's 70-76, and 77-?? Either way, yes it is an early 70's scoop.
Old 07-09-2010, 02:50 PM
1CAMWNDR's Avatar
Do the stripe in vinyl, I bet it looks killer. Thanks for confirming the scoop dates, I have an early one I am trying to get on fleabay.
Old 07-09-2010, 04:06 PM
1999Transamman's Avatar
I like it and I dont like it. I think the lines will work if you do some rocker panels on the bottom. Just an idea. The work looks clean though, you've done well so far. Check out the Year One snowflake wheels, those could really help pull the throw back to the past for your car. Then definitly do some blue stripes, that would look sick. Good job though, I cant wait to see how it finishes out.
Old 07-10-2010, 04:17 AM
jay7199's Avatar
I like it looks great after I looked at the other pics, I think it would be really cool on a lt1, how do you plan to make it functional
Old 07-12-2010, 11:34 AM
I'm still contemplating that. I actually will probably do one of two things.
1. Utilize a LT1 SS type of tube
2. Build a different box a little bit shorter, with a tapered end and do a 180 degree Silicone adapter from the end of the box to the MAF, all in the factory location.
Old 07-12-2010, 03:05 PM
Rhin's Avatar
How do you intend to prevent water from entering the intake?
Old 07-13-2010, 12:28 AM
jay7199's Avatar
sounds like a great idea
Old 07-13-2010, 01:40 AM
meine96ws6's Avatar
2 thumbs up..it nice to see something different..
Old 07-13-2010, 02:33 AM
02sleeperz28's Avatar
Different.
Old 07-13-2010, 10:25 AM
  #32
I have the solenoid that came with the scoop. It can be wired to open when the car is on, and closed when the car is off. I wouldn't think that any more water would go in this way compared to the factory location.
I also have the gasket that goes around the scoop. I can use that with the drain tube to take the water elsewhere. This way the amount of water from the scoop hole is reduced.
Old 07-13-2010, 11:02 AM
  #33
Jassick's Avatar
Looks pretty damn good so far. Could you get a picture from the inside. Curious to see what it'd be like driving that thing around.
Old 07-13-2010, 11:41 AM
  #34
Z28 Autobot's Avatar
that looks really cool.
I think the size of the scoop is not the problem..its that its not offset by the T/A wing in the back. Your formula wing makes that shaker look huge. I bet if you threw a T/A wing on it it would look killer.
Nice job. would love to see more pictures. WHo knows. you might of started soemthing.
ANd yes a blue or black stripe will do wonders.
Old 07-13-2010, 11:42 AM
  #35
It's even and level, although it doesn't look like it. The "wavy" part in the back of the whole is distorted is from the glass, and it's taken from the drivers seat rather than in the center. Plus it was taken with my iPhone rather than my dSLR like the other pictures.
Attached Thumbnails My attempt at a Shaker (project still in progress)-inside.jpg
Old 07-17-2010, 12:23 PM
  #36
Raleigh TA's Avatar
Don't get in a wreck staring at that shaker! It can be mesmerizing.
Old 11-16-2010, 10:59 PM
  #37
01ssreda4's Avatar
We need a video of the scoop in action
Old 11-18-2010, 09:02 AM
  #38
ANTICOP RAM AIR's Avatar
That setup is sick as hell.. I would trade my OEM hood and stainless lid for that in a heartbeat.... i was thinking about doing something like this to mine... a butterfly setup that opens progressively with the throttle increase...kind of like the blower scoops... let me know if you want to trade.. lol
Old 11-18-2010, 09:02 PM
  #39
1CAMWNDR's Avatar
Dropped my car off for paint today. After the paint cures for a month or two I am gonna try to get a shaker installed and a dark gray stripe up the center like the '70-'72 TA.
Old 11-19-2010, 12:33 AM
  #40
rabbit320's Avatar
looks great! for others yes this has been discussed in 6LE's thread i think in the paint and bodywork section or appearance section, in a lot more depth. i like the earlier scoop better than the creased '79 one, flows better with the curved hoods. are you doing a filter in the box area like 6LE's kit? and whats this of a butterfly valve opening? +1 on painting it white, though with a black sail panel and black mirrors it may look sinister, and use a white decal on the side...
Quick Reply: My attempt at a Shaker (project still in progress)
