Rear end
That was very informative but still did not answer my question. I need to know what size ring gear ( as far as 8.5 in or 7.5) to order from Jegs is there a way of finding this with out tearing the rear end apart? thanks for the help.
That's MISTER MODERATOR
The rears in these cars has a 7-1/2 inch ring gear.
Any seller or website (like Jegs or Summit) would've told you what size the gears are.
Are you planning on doing a ring & pinion install? If so, you have a lot to learn if you didn't even know the rear size. This installation is pretty involved and certainly not for the inexperienced.
