99 ws6 power steering fluid mixing with radiator coolant
Old 05-30-2011, 02:00 PM
WSSICK99's Avatar
Default 99 ws6 power steering fluid mixing with radiator coolant
problem with power steering fludi mixing with my coolant any way to fix this happen twice now before it was like a check valve in the coolant tubing.. im lost anyway to by pass or fix for good help please.
Old 05-30-2011, 04:44 PM
Titanws6's Avatar
The power steering cooler pipe is going bad, you'll need to replace it. This piece, mine went bad, was doiong the same thing
Attached Thumbnails 99 ws6 power steering fluid mixing with radiator coolant-power-steering.jpg
Old 05-30-2011, 05:00 PM
Bluestreak's Avatar
Mine has the same problem... I just found coolant in the PS reservoir. I shudder to think what the stock PS cooler costs... I can't find it online for sale, but I haven't looked too hard either.
I'm moving to this setup. It's simple, can't cause cross-contamination ever again, and it just makes so much more sense. Why use 190° coolant to cool the PS fluid when a simple setup like this can use 90° ambient air temps? That's 100° of additional cooling! That seems significant to me. I'm going with a slightly larger fluid cooler from a website that shall remain nameless as I don't think they're a sponsor.
-R
Old 05-30-2011, 09:24 PM
WSSICK99's Avatar
o ok thanks guys so much..... much needed info appreciate A lot.
Old 05-30-2011, 09:32 PM
WSSICK99's Avatar
hey do you kno what this peace is called
Old 05-30-2011, 09:33 PM
20TA02's Avatar
-R
i have that set up and it does the job... it works good.
Old 05-30-2011, 09:40 PM
20TA02's Avatar
step by step instructions.
http://www.noid.org/pscooler/
Old 05-31-2011, 12:53 AM
WSSICK99's Avatar
o ok awesome i need to get on that ***** annoying
Quick Reply: 99 ws6 power steering fluid mixing with radiator coolant
