Did our cars come with a power steering cooler?
Old 11-02-2011, 10:45 PM
RedVertTA's Avatar
Default Did our cars come with a power steering cooler?
I've heard from one source that all the ls1 fbodys came with a power steering cooler, then another said only ws6 cars got a power steering cooler. Which is it?
Old 11-02-2011, 11:25 PM
Mumbles's Avatar
Just brought home an 2001 Formula (Non WS6) this evening that has a Power Steering Cooler. I have a 2000 WS6 Formula that has one and my brother's 02 SS is equipped with one as well. But the 1999 Formula (Non WS6) in my signature doesn't have one. This leads me to believe it doesn't matter whether the car is a WS6 or not.
Many guys choose to delete them, due to the fact that they are prone to failure. When they do fail, you end up with Power Steering Fluid in your Radiator and Antifreeze in your Power Steering Reservoir. Not good. My brother and I plan to eliminate them from his SS and my WS6 for this very reason.
Old 11-03-2011, 04:10 AM
myk
myk's Avatar
The SS's and WS6's came with them; later during production, not sure when, I believe all V8 F body's came with the coolers. Someone correct me if I'm wrong...
Old 11-03-2011, 06:14 AM
99'CajunFirehawk157's Avatar
Exclamation
In this first pic is the factory "cooler" your speaking of,
if you have one like this (the long tube looking part connecting the two top rad hoses) take it out ASAP and avoid much misery and p/s fluid mixxed with your coolant.
Do a search and see how many fail...
And then spend $50 on parts, add one like this and you will truly have a p/s cooler...
Much info on this subject on this forum, search.
Old 11-03-2011, 09:02 AM
RedVertTA's Avatar
^^^ Mine doesn't have that tube on the radiator hose so I guess I don't have the cooler. What parts are required to add a power steering cooler? I'm tired of having fluid boil out of my reservoir.
Old 11-03-2011, 10:02 AM
Ya just need a trans type cooler like shown and some extra p/s hose, maybe a few fittings, nothing major...
Old 11-03-2011, 10:36 AM
RedVertTA's Avatar
^^^ Can I ask you what are the dimensions of the cooler you used? And what kind of clips are those holding it in?
Old 11-03-2011, 10:44 AM
http://www.amazon.com/gp/product/B000C39C86
the mother of all fbody ls1tech power steering cooler info threads...
https://ls1tech.com/forums/general-m...g-success.html
Old 11-03-2011, 11:46 AM
RedVertTA's Avatar
^^^ Wow, I never saw that thread. Thank you very much for the links and info.
Old 11-03-2011, 08:27 PM
That's MISTER MODERATOR
Paul Bell's Avatar
My '99 TA did not come with the POS cooler...er, I mean the PS cooler. Thankfully.
Old 11-04-2011, 03:39 AM
myk
myk's Avatar
Wait a minute. Based on where the stock cooler is located how is that supposed to cool the fluid?
Old 11-04-2011, 03:41 AM
Captain Double Post
BOBS99SS's Avatar
agree with cajun , i had hell with mine
Old 11-04-2011, 05:16 AM
Paul Bell's Avatar
It works just like the stock transmission cooler.
Old 11-04-2011, 05:40 AM
Thumbs up
Like a lot of things on our cars that factory POS may have actually heated up the fluid more then it did cool it... I can tell you this, when I installed my new cooler, I layed under the car for at least 20 mins checking for leaks and was amazed how hot the tubes on the new cooler got just idling in the garage....
Old 11-04-2011, 08:17 AM
babbage1109's Avatar
My 01 didn't have one.
Old 11-04-2011, 10:23 AM
firemech21's Avatar
My 99 t/a, came with a cooler. Honestly I talked to a couple different stealerships and it all depended on who speced out the RPO codes for the car. So if they wanted the cooler it was an extra charge/option.
Old 11-07-2011, 11:34 AM
JohnnyBs98WS6Rag's Avatar
RPO V12 (COOLING SYSTEM,POWER STEERING FLUID P/S CLG SYS(V12)) was originally installed (as standard equipment) only on SS and WS6 cars in '98, then it became a option on cars other than the SS and WS6s in '99-'01, then all LS1 F-bods got them in '02.
Old 11-15-2011, 12:01 AM
41863nj's Avatar
my 2000 WS6 has it...
Old 11-22-2011, 04:31 PM
Tire Smoking Tranny Blowing Director
Cool28's Avatar
Hmm I bet I could use my old stock trans cooler for a powersteering cooler
Old 11-24-2011, 06:21 PM
cpop98ta's Avatar
I also got rid of the factory cooler and mounted a new one in front of the radiator.
Quick Reply: Did our cars come with a power steering cooler?
