68 firebird t top or targa?
I cant find pictures but I remember an Ebay ad from a few years ago, a guy had a prototype Hurst First Gen Camaro with T-Tops, installed by Hust (so he says, but had a lot of documentation.)
I've never heard of a prototype 1st gen hurst t top car- would love to see it.
I have seen the 'fitchbird' before and it did not have t tops.
Come to think of it- the George Barris 'Superteen'
Cars built in 68 might have had t tops
I would recommend doing some photo shop editing first if you don't find an example to reference.
Personally, I'd have to agree with MiniLSX about the lines not flowing well. The clash I'm envisioning is the fact that a first gen has rear windows and is a hard top. Cars with either t-tops or targa tops typically have a vertical c pillar. Your car doesn't, and when the windows are down/ roof is off the "leaning forward" roof section might look weird.
Would you shave off the drip rails? Would you have a roof section made, or would it be a permanent open car?
But this is not to say you shouldn't do it. It's you car, go for it if you want. And, if you change your mind restoration parts are available to return your car to stock. I speak from experience. I'm sure the Pontiac purists would have a fit if they saw all the mods I'm doing to my '67.
http://www.hotrodders.com/forum/jour...39&action=view
Banned Scammer
targa all the way. go custom.
chop it off urself. you can use the ttop lock-in idea...
use the same brackets as used in the 92-02 f bodies and weld them at the same/or close too the same position as they are on the fbodies.
then youll have to fab up some kind of locking mechanism to go on the targa.
i wouldnt attemp to do a glass one, just stick with the sheet metal. as for weather stripping. use your creativity
Now, we all know the first gens did not have t-tops, but the second gens did- 6 years after they came out. they were obviously not originally designed for them. The original "Hurst Hatches" were designed for another car/ roofline. As such, they leaked badly. The Fisher brand t-tops were not much better. Either t-top design were more prone to flex and this is why drag racers prefer the non t-top models. Same for the third gens.
Now, the 4th gens were actually designed with the T-tops from day one. I know this for fact as I had a discussion with one of the 4th gen designers when I took transportation design in school. Also, this is why it's so easy to add the t-tops to a non t-top car- the structure is already there. All you're doing is peeling away the skin and adding the components.
I have no factual information on the 5th gens, but, seeing that they have not offered them by now, I would conclude that they are not intending for them as they have drop down airbags, etc where the t-tops would otherwise be.
I hope this helps.
