engine and trans removal
How hard is it to pull a 1998 3.8L buick V6 from a 98 Firebird?
it and the transmission are leaking so I want to rebuild them until I can afford to buy a better driveline for the car.
I need to know if the car is a 3 channel or 4 channel ABS... :/ Do I need to drop the K-member for sure?
What I want to do is drive the car up on ramps, then jack up the rear end and put jackstands under the rear so I have room to get under, yet the car isnt too high for me to get into the engine compartment.
You'll definitely want both ends in the air. The front will need to get really high to clear the motor/tire combo to roll it out. I dropped my K member on to a dolly so the car didnt have to be as high the last time I did it. 3 channel is abs, 4 channel is traction control. I dont believe 4 channel to be an option on V6 cars.
Cherry picker is the best way to do it if you dont have a lift. Usually lift cars by the core support or bumper bars. Honestly not sure on these cars though.
The back being lifted up worries me. Guess the rear bumper touches before its high enough to clear the motor enough to slide out?
I had the front bumper off so I used the bumper support. Thought about making a strut tower bar to use though. My rear end pivoted nicely in the jack stand. Placed them as far from center as possible, with the radius in the axle along with a little grease, just cuz I have tons of it.
With the rear of the car on the ground though, the angle of the car is extreme to get it all out. Picture this / versus only a slight increase in angle with the entire car lifted.
so if I had a strut bar thing and lifted off the front too, would that put less stress on the car?
or if I had a two-post, could I just lift the body off the engine?
