engine swap on my 2000 ws6
Old 03-18-2013, 08:03 AM
ws6guy27's Avatar
Default engine swap on my 2000 ws6
Needing help deciding easiest n safest way to pull 383 ls6(for sale) n put in ls3 418.. dont have lift. Heard can drop motor n lift car off engine. Nervous by myself.. need all suggestions I can plz help
Old 03-18-2013, 08:10 AM
Blackpanther99's Avatar
A lot of people tend to have a easier time dropping the motor down than pulling it out from the top with a crate lifter. Do you have a lift?
Old 03-18-2013, 08:36 AM
'99REDTA's Avatar
Dropped the engine out of my mustang at the shop on base more times than I'd like to admit. Its super easy if you can do it that way (ie have access to a lift) but what sold me is theres almost no way to screw up your paint and stuff
Old 03-18-2013, 10:55 AM
ws6guy27's Avatar
No dnt have access to lift.. I know sucks.. but I needing pull motor in abt a dsy or two
Old 03-18-2013, 11:14 AM
99WS6_'s Avatar
x2 anybody know how to lift up the body without having a lift
Old 03-18-2013, 11:20 AM
btownws6's Avatar
pretty much need a lift my friend
Old 03-18-2013, 01:53 PM
ws6guy27's Avatar
Well I dnt have one. So I guess I gotta pull it the hard way?
Old 03-18-2013, 02:04 PM
Jake18's Avatar
i dropped my motor out the bottom. i got the car high enough with some blocks and jackstands. it worked fine for me, just take the lip off the bumper and it'll clear.
Old 03-18-2013, 02:47 PM
'99REDTA's Avatar
Good god dude you put in work. that front end is up there
Old 03-18-2013, 03:06 PM
99WS6_'s Avatar
How about the back bumper lmao thats how i will have to do it
Old 03-18-2013, 05:13 PM
LPE 403's Avatar
Put the rear wheels on ramps and elevate with a few 2x12s. Support the cradle assembly with a cart to ease moving it around. Worked great for me....
Old 03-18-2013, 07:55 PM
pontiac_boy's Avatar
I've done it this way, with a lift and pulled them out the top. A lift is the easiest way but this way is not near as bad as out the top. I pulled my exhaust and rear bumper just to be on the safe side and lifted the front to the moon.
Old 03-18-2013, 09:06 PM
ws6guy27's Avatar
That looks crazy lol.. so if I end up parting out motor. Would it be easier out the top?
Old 03-19-2013, 08:40 AM
CopMagnet's Avatar
Smokinponcho73 in PNW forum has like railroad ties he chopped and stacked. It's sitting on those with 4 stands underneath. The middle is cutout for crawl access.
Old 03-19-2013, 09:08 AM
MertezWS6's Avatar
If you do not have a lift, do your car and yourself a favor and just go out the top. It would suck to drop you car lifting it all sketchy. I did mine out the top lifting it on jack stands about a foot or so, car stayed there the whole time then cherry picked it out the top, don't remove hood cause there a PITA to line back up perfect, then when your coming out have a friend disconnect the hood shocks to have hood go further back and it should come right out. Its even easier when you have trans out but still an easy job coming out the top and would do it again, all you need is like 4 feet in front of the car for cherry picker.
Old 03-19-2013, 11:00 AM
CopMagnet's Avatar
Yeah, dropping the car would suck. Nice job with that space Mertez. Smokinponcho rigged up his rail road ties like a drive up ramp style. Guess I like his setup.
Old 03-19-2013, 07:10 PM
Asite57's Avatar
I've never seen a V8 pulled out the top on an Fbody, did it with a V6 and it was a pain in the ***. IMELDA lining up a hood isn't hard done it 100 times never took more then 10min
Quick Reply: engine swap on my 2000 ws6
