What upgrades should I do next...?
I have a 2002 Collector Edition Trans Am and I've run out of obvious upgrades to do for it. So far it has:
Exhaust:
Dynatech Supermaxx longtube headers with high flow cats
Borla cat back exhaust system
Induction:
K&N Air Filter
SLP air lid
85mm bbk throttlebody
high flow MAF
Maintenance:
oil catch can
Royal Purple oil
Driveline:
4.10 differential gears (no idea what brand, previous owner installed them)
Monster Level 2 clutch with monster slave cylinder and 28 lb billet steel flywheel
energy transmission polyurethane trans mount
Ignition:
performance plugs and wires, can't remember the brand but I don't think they're the best out there.
Suspension/Tires:
Front/Rear Sumitomo tires: 275/40/ZR17 | 315/35/ZR17
SLP Front Strut Tower Brace
bilstein shocks/struts built to SLP specs
So, what should I do next? I don't want to push more than 450 to the wheels due to the wear and tear on the drive shaft and other parts. It's my only car and I drive it for work so I can't do an excessive cam. I do want to get a new intake manifold so that's probably what i'll do next, or i might do performance oil, water and fuel pumps as well as fuel rails. I also need to go to a nearby shop and get it professionally dyno tuned, but what's everyone else's opinion, what does it need?
Exhaust:
Induction:
K&N Air Filter
SLP air lid
high flow MAF
Maintenance:
oil catch can
Royal Purple oil
Driveline:
Ignition:
Suspension/Tires:
also, what does the tick master do? i've never heard of it.
I daily mine with a decent cam, not too bad once you get used to it. I'm untuned which I think goves me much of my problems because its so lean but it hate hate hates when you expect it to move when its cold
Hmm, i've always been curious about how the cold air intake works with the ram air? that's why i've stayed away from it. the slp kit looks like it would eliminate the ram air, which is something i did not want to do.
http://www.tickperformance.com/tick-...or-ls1-f-body/
Is it really that big of a difference? I think my car needs one since the new clutch because its hard to get into reverse now, but the drill mod really helped keeping the pedal from sticking to the floor unless I got lapped it
I've never had it on any of my personal cars but have driven a buddy's car several times. My old T/A's clutch used to stick to the floor as well. I had bought a Tick Master for it but sold the car before I had it installed. Mine was a pain to get in reverse at times as well. I don't think I've seen one negative review for it on here. I'm waiting to pick one up used as they are pricey new.
I used to have the same mindset but throwing power mods at a car that can't shift at high RPM or you have to think/worry about when you do doesn't make sense to me. My T/A had this problem fairly often due to mileage/abuse. I haven't driven my current car yet since I'm overseas but I'd still rather have the peace of mind.
