Starting problem - 6 speed
Old 12-14-2013, 06:51 PM
johnfin's Avatar
Default Starting problem - 6 speed
Sometimes my car wont crank over. Then after a second it cranks over just fine. The battery and terminals are fine. No clicking or slow cranking. Could it be the neutral safety switch on the blink.
Old 12-14-2013, 07:07 PM
fruitsalad's Avatar
Is the security light on the dash on or blinking while you try to crank it?
Old 12-14-2013, 07:19 PM
JC316's Avatar
Probably the clutch switch acting up.
Old 12-14-2013, 11:38 PM
great421's Avatar
Default My $0.02...
If it is a Clutch Pedal Position Switch, then DO NOT get anything other than a real GM part - I broke 3 Autozone units in 3 days, then I put on a GM unit and I've been going strong for over 5 years.
If that, however is not the problem, then find your VATS relay and make sure the very small BLK / WHT ground wire is not loose in the relay mount / 4-pin connector.
This was also a problem on my car; after I secured the GND wire (so the VATS relay would actually trip and then allow B+ to flow to the starter!), no more random starting issues.
Good luck!
Old 12-15-2013, 08:33 AM
johnfin's Avatar
Default relay
where is the vats relay located in an 02'
Quick Reply: Starting problem - 6 speed
