New member, need advice.
Hi everyone. Just bought a 2000 Trans Am auto last night and have had some bad luck already.. Not the car itself luckily.
When I went to pick up the car last night the rear driver side tire was flat. Luckily the previous owner had included new tires for me to install. So I grabbed the wheel with the flat and one of the new tires and went to Tire Kingdom in Orange Park, FL. The old tire was getting flat due to a bad valve stem so I had them replace the valve stem when they were doing the tire.
We then installed the tire in the car and drove off.. I let my friend drive it while i drove my other car. Not more than 10 mins of driving I see hes got a flat and flag him down as soon as possible. Basically the valve stem they put in was too long and hit the caliper and broke.
So, now I had a flat tire and part of the rim was damaged. I waited almost two hours for a tow truck and had it towed to the tire place that did the work, but they were already closed. I got up early morning and went to talk to the service manager.
The service manager says to me that it's not their fault that they put in a standard size valve stem and it hit the calipar.. and also that they didn't put on the tire, if they did, they would have noticed the stem hitting the caliper. They will fix the valve stem issue, but not the wheel damage.
So what I would like to know is what I can do? Am I out of luck? This car doesn't come with the stock wheels, but some boyd coddingtons. The valve sits further in than any car I've used in the past. Is the valve stem on the stock wheel short too or a standard size?
Thanks for any help in advance,
Al
For your enjoyment
Al
For your enjoyment
First off that's why you never go to Tire Kingdom, the ultimate minimum wage, high turnover, 'no knowledge' lot of employees you will ever encounter IMO. It was that way in the '90s when I lived in FL and I see it has not changed.
Next up, go to your local courthouse and start the small claims process going. Don't waste your breath with the local manager. He is useless and I'm not surprised. It's never their fault! If you want to go over his head you might consider that but you never know. Any knowledgeable tire installer would have seen the potential problem with those rims. It's ridiculous, and I'm sorry you went there. Don't let it spoil your Trans am ownership experience. Just chalk it up to 'experience'.
I wish I didn't go there.. But when I tried finding a place around 7;30pm, they were the only ones I could find that were open. I've never heard of the place actually.. I just moved to Jax recently from NY. I called their customer service dept.. apparently it takes 24-48 hours to get a response. I'll wait to see what they say.. If I hear things I don't like, I may take them to court.
You're right Keven, someone should have realized.. But I think they were too busy taking my money and sending me off. Clearly they expect the customer to be the tire professionals and have the knowledge.
That's MISTER MODERATOR
First, congrats on the nice new ride!
Second, NO, Tire Kingdom is not responsible. You didn't tell them the wheel needed a short stem. They didn't mount the wheel onto the car to see the stem would hit the caliper.
This should've been spotted by whoever put the wheel back onto the car.
You walked into Tire Kingdom with a flat in your hand, not on the car. They fixed the flat and you rolled the wheel out. Fixing the flat using standard parts was "proper" work on their part. You didn't ask for a special valve stem. They're off the hook and no judge will side with you.
I get a big fat zero for reader comprehension.
I didn't realize you walked the tire in. That is indeed a different scenario. They could have asked but that wouldn't cut it in a court case. Never mind the small claims advice. That would only be valid if they put the tire on the car. My apologies. Sorry about the rim. That stinks.
