2000 Trans Am exhaust question????
Old 04-23-2014, 02:17 PM
kaw395's Avatar
Default 2000 Trans Am exhaust question????
Not sure where to post this. But i have a 2000 Trans Am with the ls1. Just got my headers and am planning on running them with the stock cat back. Anyone else done this? Just looking to get a little better sound out of it. Does anyone have a video of a car with a similar set up? Thanks
Old 04-23-2014, 02:24 PM
HCI2000SS's Avatar
Why choke those headers off with a stock cat back and muffler? Just curious
Old 04-23-2014, 02:55 PM
BAN_ONE's Avatar
I'm with HCI2000SS not sure why you would want to fork up the money for headers and then run stock exhaust.. I don't think you'll find anyone else running that set up but you can check this thread out if you haven't already for ideas
https://ls1tech.com/forums/generatio...ounds-com.html
Old 04-23-2014, 06:05 PM
teh PuRpL3z
DrEvyl's Avatar
Seems like it would make more sense to do the catback first, then the headers, otherwise you're negating a lot of the benefit of getting headers in the first place. The catback would be a much better way to get an improved sound out of it.
Old 04-23-2014, 06:59 PM
Pseudonym's Avatar
It wont fit if you got long tubes. If you got shorties, you may be able to run the stock catback. I would recommend a magnaflow or hooker catback.
Old 04-24-2014, 03:16 AM
kaw395's Avatar
Just did headers to delete the converters on my car. Everything I have read says that the stock manifolds are really restrictive. I have a friend that put a cat back on his ls1 camaro with the converters and it didn't sound any different than mine does now. And didn't want to spend the money on the cat back and headers at once. But I guess if it's not worth doing headers with stock muffler I'll have to look into a cat back. Just don't want anything crazy loud that will have people grumbling over it.
Old 04-24-2014, 03:45 AM
Daniel Richards's Avatar
if the goal is just to delete the cats, thats what the "off-road" y-pipe if for, just have to find one that works with the headers you want.
but if you can't afford to do it all at once start with the cat-back first then do the headers later, headers cost far more then the cheaper cat-backs, Keep in mind you are NOT limited to just LS1 cat-backs, you can use LT1 cat-backs and just cut the s-bend off the I-pipe to meet up with the y-pipe in the tunnel and swap some hangers. I picked up the Hooker LT1 cat-back brand new off Advance Auto website (searching by the part number) for like 320 (using a 50 off promo code), which i'll bet is cheaper then those headers.
you gotta think, what good is increasing the flow at the start of the hose if the flow in the rest of the hose still sucks. also going Cat-less will give you rasp.
Old 04-24-2014, 06:29 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Kaw, I'm not understanding how you were going to install headers without a matching Y-pipe. The cats are in the Y-pipe.
Old 04-24-2014, 06:47 AM
kaw395's Avatar
Sorry. Guess I didn't say I ordered a set of bbk long tubes with the off road y-pipe. Looking more for sound now more than performance. Just wanted to see what it would be like until I bought the cat back.
Old 04-24-2014, 08:37 PM
Paul Bell's Avatar
Gotcha. Update us with the results!
Old 04-25-2014, 04:24 PM
z-maro's Avatar
The first bolded part is not true. I agree with the second part however.
Here is mine with LT's and ORY into the stock catback:
And with the hooker catback:
Old 04-25-2014, 04:32 PM
98CayenneT/A's Avatar
I am also running long tube headers with ory and stock cat back with aftermarket muffler, no fitment issues here and sounds very good
Old 04-25-2014, 06:23 PM
kaw395's Avatar
Thanks everyone. I'll eventually do the cat back. But for now I'll try running with stock muffler. I'll update it as soon as I can get it all hooked up.
Old 04-25-2014, 11:10 PM
black79transam's Avatar
My set up will be the same. Stock muffler replaced with a magnaflow otherwise 1 3/4 headers, tsp ory, into the stock catback with the magnaflow muffler.
Old 05-08-2014, 05:48 AM
kaw395's Avatar
Got the headers on last week. Mounted up with no issues and matched to the stock cat back perfectly. Great sounding and not to loud. Will eventually do a different muffler, but for now I'm leaving the stock one.
Quick Reply: 2000 Trans Am exhaust question????
