Spare tire cover screw fasteners
I think moderndaymuscle.com has them also.
Save the manuals!
^ Ah. That happened to me, too. You need a new seat belt, with retractor. That piece is sewn in to the unit. Replacing that part requires properly torqued bolts, so if you don't have a good torque wrench, you'll need to get one or have someone do the install.
The good news:
- GM still makes these parts. (They are required to keep the cars still on the road safe.)
- GM changed the design to a new one-piece buckle design that doesn't have this problem.
The bad news:
- Your passenger buckle will not match your driver's side after the swap.
- When I switched mine out a few years ago, the old style passenger belts were still in stock. I switched my passenger out at the same time - and mine still don't match.
I don't think the problem is a safety issue, but having that piece broken is really annoying because the buckle slides down the belt when you have the unit unbuckled.
The good news:
The bad news:
That's MISTER MODERATOR
The good news:
The bad news:
The bad news:
I have this exact problem and I'm gonna go see Bubba and get L & R belt sets.
Save the manuals!
My guess is that this design is a lot more tolerant of being slammed in the door!
If you get two new belts, you could end up in the same boat as I am in, with two non-matching buckles. I figured replacing both seat belts after 15 years was worth it just to get clean locking mechanisms, etc. since they can't be serviced.
I do like the new design - just wish I had a passenger belt that was the same.
