Problem when i brake. 99 trans am.
Old 09-08-2014, 10:43 PM
FireTA99's Avatar
Default Problem when i brake. 99 trans am.
Sometimes when I'm driving and I brake I feel like the car shakes or stumbles. I'm not slamming on the brakes either. It usually happens when I'm driving 50+ and I have to brake but no matter how slowly I brake it always feels like it shakes. How can I fix this?
Old 09-09-2014, 10:18 AM
JohnnyBs98WS6Rag's Avatar
Rotors & brake pads need to be replaced.
Old 09-09-2014, 10:33 AM
vanwyk99's Avatar
warped rotors
Old 09-09-2014, 10:57 AM
TechCam97's Avatar
Yep, yep, change out your pads and rotors and you'll be fine. Mine was doing the same thing and I replaced everything with the BrakeMotive kit and it has worked flawlessly since!
Old 09-09-2014, 11:18 AM
FireTA99's Avatar
I like this. How much does this kit cost? Would you recommend any other brakes? Like c5 brakes?
Old 09-09-2014, 12:18 PM
TechCam97's Avatar
They used to be a sponsor on here, I'm not sure if they are anymore. I'll send you a PM with where I got them from and how much they were.
As for other brakes, I haven't used any other brands, but many people on here have used Baer, Stoptech, RPM Speed, and others with varying degrees of success.
Old 09-09-2014, 12:27 PM
FireTA99's Avatar
The red calipers come with the kit?
Old 09-09-2014, 01:21 PM
Iroc4u89's Avatar
If you do new pads and rotors make sure you clean the caliper slides.
Old 09-09-2014, 02:36 PM
Tipnitty's Avatar
You paint them yourself I would assume.
Old 09-09-2014, 03:48 PM
TechCam97's Avatar
No, I painted my stock calipers myself.
Old 09-09-2014, 04:04 PM
FireTA99's Avatar
Will do.
Old 09-09-2014, 04:07 PM
FireTA99's Avatar
Looks real nice. I'm going to do that as well. Any problems with the kit?
Old 09-09-2014, 04:15 PM
TechCam97's Avatar
No, everything went together nicely!
Old 09-09-2014, 06:54 PM
That's MISTER MODERATOR
Paul Bell's Avatar
FireTA99, welcome to LS1tech!
I've been through a few dozen rotors in my time. I've bought cheap, expensive and high end really expensive rotors.
I've found that even the cheapest rotors perform almost on par with the most expensive ones. These days when I need rotors, I look for Plain Jane blanks, no holes, grooves, nothing. It's PADS that make the difference-and calipers in good working order. They need to slide properly on their pins-which should be greased.
I use YellowStuff pads from EBC. Worth the bucks.
When driving, the rotors get hot-especially after braking down from speed. Avoid puddles or getting the rotors wet when hot. Washing the car? See that steam coming off the rotors? That's your rotors warping.
Old 09-09-2014, 09:27 PM
FireTA99's Avatar
I live in Texas, in the summer it gets really hot. My rotors are warped then.
Old 09-09-2014, 11:09 PM
Paul Bell's Avatar
With the temperatures the rotors attain, the outside ambient air temperatures really don't affect rotors ability to absorb or dissipate heat.
Get yourself some new rotors, decent pads and make sure the calipers are all good.
Quick Reply: Problem when i brake. 99 trans am.
