needing help with diagnosing problems
My car has an A4 and coming out of first gear into second it shifts really rough like wheels break loose and throws me into a slide kinda rough but all other gears are good no signs of slipping or anything...I've tried manually going through all gears and the same thing happens...is it in need of a rebuild or should I just not worry about it
Also my airbag light won't go off...could this be cause my donor was totaled? and what would I need to do to get this light off my dash? Flash pcm maybe?
Last but not least my smog pump...I'm getting a code saying something about my pump solenoid and when I googled it and started looking my car over it doesn't have a solenoid...no plug no vacuum lines nothing and it doesn't have a diverter where the tube splits to go to the headers either...should my car have these parts? Or did some trans ams not come with these...and if that's the case why is it throwing the code?
Any help would be much appreciated
That's MISTER MODERATOR
1: Sounds like you'll be re-building that transmission pretty soon.
2: The airbag system can be scanned to tell you where the problem is.
3: The PCM does a test of the A.I.R. system. If it's not working or has been removed, you'll get a trouble code for it. This test can be tuned out of the PCM. PCMforless and other mail order tune companies can easily do this.
Hey Paul I noticed today while I was running some errands that when the motor and trans got good and hot the trans started shifting smoother into second...could this be a filter problem or am I still looking at a rebuild?
Things usually get worse when they get hot.
A "good" transmission should shift properly at any temperature or amount of running time.
The only thing is when cold, an automatic transmission may shift a little firmer due to the cold (higher viscosity) of the fluid.
here's a thread on the subject of your shift issue:
https://ls1tech.com/forums/automatic...ift-issue.html
mine does this sometimes when it gets hot enough, I first noticed it well over a year ago after driving for like 45 minutes (my daily driving usually never runs longer then 30 minutes at a trip), when it does it it also firms up the other shifts, but to a much lower extent.
I have money set aside for the day the trans finally gives out, along with a transgo shift kit and corvette servo to go in when the rebuild gets done.
It's been 17 months, a 1,400 mile round trip to Florida plus a daily driving of about 3k miles ever 2 months since the first time it has happened (thrown a p1870 code 2 or 3 times) and my trans is still going, but then again it's only done it to me maybe a dozen times during all that time (the hard shifting).
drop the pan, inspect the fluid, inspect the parts referenced in the linked thread and maybe you might get lucky and just need fresh fluid.
In my v6 my trans it was shifting hard after a while of driving like yours is doing and when I had it rebuilt they said the trans was overheating and causing worse problems with the clutches and everything internal...might be some of your problem
Ill check that link out and see if I can find out any info I'm a mechanic and ill do a lot of things but transmissions isn't one of them I try and stay under the hood lol thanks for your help
