I've never been so mad in my life with these bmr springs and Koni shocks
So I'm no stranger to lowering a car. I've been in the garage for 6 hours last night and by putting on the bmr lowering springs, heater hose mod, Koni sport shocks.... It raised my car an inch 😳. I can't believe it. The car measured 27.75 in the back before the springs and now it measures almost 29. I know cars need time to settle but this is a little ridicules. Every one else I see with this set up is around 26 inch wheel gap in the rear. Do you think something is defective?
The first pic is before the swap and the 2nd is after. For over $1000 i was expecting something better
i commented in your other post , its not the springs , its your shocks or you have bind somewhere. Look how short the springs are , take the shock off and drop the car down on just springs and i bet it will be fine . Either you shock is messed up , put together wrong or you have bind . Did you loosen your lcas and then tighten them up without a load on the suspension?
what you are probably experiencing is bind of some sort. those poly busings tend to get preload and when you try and lower it with a pre-load they bind and actually keep the car from settling.
Best thing to do is to get under the car with it on the ground or lift it and support it by the rear end and not the body. loosen the nuts and bolts on the Pan hard bar as well as the swaybar mounts and endlinks. Just loosen them you dont have to take them completely off. than tighten everything back. This will take the preload of your stock rideheight off this system and adjust it to your new height with the lower springs.
you may also need to do this for your lower control arms.
Not saying its impossible to get bad parts, but its a pretty common issue with fbodies when you lower them that the rear poly bushings cause some issues getting the body to correct to the new ride height. You may also find that you need an adjustable panhard bar if you dont have one already to recenter rear at the lower ride height
was/is the parking brake on? has the car been DRIVEN, like even around the yard since the install? lets cover the basics before you start tearing things apart. are those big *** 315's hanging on the bump stop because you didn't buy an adjustable panhard bar to re-center the rear end?
No parking break on, clears bump stops. Driven around the block, even jumped in the hatch for about ten mins ... Here's a pic without shocks in the car lowered
LS1Tech Premium Sponsor
You are trying to put the front springs on the rear of the car. The two front springs will have the part number SP002 on them and the rear spring will have the part number SP003 on them. Swap the spring around and you will be good to go. If you have any other questions or concerns please just give us a call.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Yup totally my fault. I was reading a forum on how to install lowering springs on LS1tech and whoever made the tutorial had the part numbers mixed up. Thanks for all your help. Works great now .... P.S I feel like a moron lol
^ dont feel bad its the kind of stuff that makes for fun stories, plus you were smart enough to realize it wasnt right, just wasnt quite sure the cause.
Kind of like back in april how I noticed my car wasnt driving right only to find out it was a melted plug wire..... that I didnt even notice when I changed the plugs that same month.
