Omg I'm so mad at these bmr springs and Koni shocks
So I'm no stranger to lowering a car. I've been in the garage for 6 hours last night and by putting on the bmr lowering springs, heater hose mod, Koni sport shocks.... It raised my car an inch 😳. I can't believe it. The car measured 27.75 in the back before the springs and now it measures almost 29. I know cars need time to settle but this is a little ridicules. Every one else I see with this set up is around 26 inch wheel gap in the rear. Do you think something is defective?
The first pic is before the lowering springs were installed and the 2nd pic is after. If you could help at all that would be great
Originally Posted by MidwestChassis2
What do you have for lower control arms and panhard bar? If they are poly I'd make sure they are not in a bind holding the vehicle up.
I took it for a drive and then spent 10 mins jumping up and down on it. Seems like it got even higher after doing so... All logic is thrown out the window on this smh
LS1Tech Premium Sponsor
You are trying to put the front springs on the rear of the car. The two front springs will have the part number SP002 on them and the rear spring will have the part number SP003 on them. Swap the spring around and you will be good to go. If you have any other questions or concerns please just give us a call.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
Yup my bad... I was reading on the forum and what I was reading had the wrong part number for the springs.. All is good now. Thanks guys
