Cruise Control, Throttle Cable, & Throttle Body
So I have a 98 Firebird that originally came with the v6 and automatic. I'm swapping in an Ls7 and T56 manual.
Planning on running a Fast 102.. Unsure on the throttle body, which may hopefully be influenced from the feedback I get here. I want to run the works in this car.. AC, Cruise, and ABS. I don't plan on racing it 'legally' much, other than the occasional track day and autocross.
From an aftermarket standpoint, are any of the top 102mm throttle bodies (ie. Nick Williams) compatible with cruise control?
TIA Ls1tech.
TIA Ls1tech.
Last edited by LS7Bird; 01-16-2017 at 07:40 PM. Reason: 1/16/17 Removed & moved questions to appropriate thread
Save the manuals!
No reason to move since the question about what to do about the cable answered here and through the Conversion stickies.
Are you looking for more information on what type of cable you need for the donor? If so, that specific question is better answered in the F Body forums.
I don't want to run an electronic throttle body/cruise, but if I have to, so be it.
Note to wssix99: I did find that the 98 v6 cruise operates the same way as a 98 v8 cruise, but it uses a different cruise module as I suspected. All of my conversion questions in this topic are now covered, but I'll be sure to use that thread you created later.
Save the manuals!
The external accessories on the LS engines are different from car-to-car. So, the external bits and pieces of a Corvette LS1 are not compatible with a Firebird LS1 of the same vintage. (The pulleys stick out different distances from the engine, accessories are mounted in different locations, etc.)
So, if you want a perfect cable fitment, you'll want to mimic the placement of your cruise control module from the car that you took the cable off of. Likewise, the throttle cable will differ depending on the car, the routing of the cable, the pedal set, etc.
So, I'd think you'd want the cables off of a Formula or T/A and I'd just take a cruise module and cable from the same car while you are at it. Hopefully your stalk can control the V8 module. (I'd think the V6 and V8 would only be different in the strength of the servos or actuators inside.)
