Pontiac GTO 2004-2006 The Modern Goat
are 05-06 axles stronger than 04 axles?
Old 10-23-2010, 08:36 PM
RE AND CHERYL's Avatar
Default are 05-06 axles stronger than 04 axles?
What the title said, I've heard this twice now and wondering if it was true and what the difference was between them.
Re'
Old 10-23-2010, 10:58 PM
Joeyelbows's Avatar
The only thing i heard about 05-06 is the differential and driveshaft are a little tougher cause the flange and drive shaft are a little bit bigger.
Old 10-24-2010, 05:09 PM
gconnoyer's Avatar
For 05/06 they did revamp the halfshafts.
The axles for the ls2's are a little beefier than the ls1's
Old 10-24-2010, 08:14 PM
Karr's Avatar
The LS2 is a little beefier than the LS1
Old 10-28-2010, 08:46 PM
batboy's Avatar
Originally Posted by Gforce1320
The 04 axles have a smaller outer splined end and a really odd ball cv joint with smaller internals that the inner cv joint.
The 04 shafts will have a part # AB2704 92067184
The 04 outer shaft dia is right around 1.1" and the 05-06 dia is 1.25"
The 05-06 half shafts will interchange with the 04's, they have the same bolt pattern and are the same length. They bolt right in.
Yeah, the 05/06 are a little beefier.
Quick Reply: are 05-06 axles stronger than 04 axles?
