Drag Bag install we did today...PICS
It's for tuning. The right side gets a higher load on launch, and requires more pressure than the left side. Ideally the car should leave/launch with the rear bumper level. On my GN I used to run a right side bag only. The guys that ran both bags ran 9-12psi right side and 6 or less left side. Maybe someone here will share their pressures on the GTO.
This is how I choose to put the schrader valves
http://www.fquick.com/garages/viewga...wimg&id=292417
I just installed the Gforce rear coilovers today. I havent had a chance to test and tune them yet.
i know this is an old thread but maybe someone could help me out anyways. Me and a buddy are wanting to put these on our camaro's and we were thinkin about going halve's on a pair where we just run one bag each, but i also see alot of people use both bags. which is better? do you gain more using both or is it ok to just use one? please if anyone could answer i would appreciate it.
If you get a leak it's easier to trace it and if you do any road racing or hard cornering you can get bleed over from one to the other. I run mine at 6 psi normal driving and 19 psi at the track.
