Help getting off the line with a turbo car
Fellow brochachos. I’d like some input from you guys. So yea, I have a heavy gto. I’m having a time getting it moving till it comes into boost. I had a 3600 stall and it would consistently pull a 1.7 60ft leaving in vacuum. I don’t have a launch control. Now I have a 3200 but I did go down on the cam. I was hoping the cam would counteract the smaller stall. Guess it didn’t. Best I could muster last night was a 1.86 foot braking to 2000. Then it would want to push or break the tires loose. Off the line there’s no traction issues at the moment. For those of you don’t know here’s the specifics
sbe 5.7
dorman ls2 intake
summit ghost cam
ss 3200 stall
billet 7875
2004 gto
3.46 gears
so should I change the stall? Or add a launch control? Do I run the risk of butting rings with a launch control?
sbe 5.7
dorman ls2 intake
summit ghost cam
ss 3200 stall
billet 7875
2004 gto
3.46 gears
What wheels/tires are you running? That is just as important. Maybe your problem is with that. Are you trying to cut a low 60 ft. time on an 18" drag radial? I know this seems like obvious stuff, but since you didn't mention, I asked.
If you're launching in vacuum and trying any higher/harder the tires break loose then leaving in more boost doesn't solve anything. You need a better tire to start. Then get a 2 step on that thing or work on the tune some more. Should be able to build at least a couple PSI on launch.
I agree, but my stall would only footbrake 2000, its a little 3200. I dont start building boost till 2500 no matter what I do, so a better tire wont do much for me there. However, if i apply the emergency brake i can build boost, but I dont see any tire being able to hold like that. If I had stronger rear brakes, which ive considered. Gonna try the stall first. if I can leave on a couple psi, i'll be good.
Hey guy....I'm back. Most of you know i hurt the motor. Just put a new one in (5.3) and had the stall adjusted from 3200 to 3600. Now instead of stalling to 2000 on the footbrake, it'll stall 3000 (odd?) on the footbrake. Still no boost on the foot brake. Can I retard timimg in that load area maybe, that way I can give it more throttle before it brakes the tires loose? think that will help?
hmmm. Seems like with added timing vs retarded, it would make more power (to an extent) and push through the brakes even harder. I’m no pro or real experienced tuner, but taking timing away seemed to take power and response away.
I’ll try it tho.
meant to put that in this post earlier. Was in a hurry.
