Race Stars are on the goat
ordered some race stars a few weeks ago. finally got the tires mounted up and installed the wheels today. 15x3.5 front and 15x10 rear with hoosier tires all around.
I ordered the wheels from a local shop that just became a distibutor.
sizes are front- 15x3.5 with 1.5 backspace. 5x4.75 lug patern
rear- 15x10 with 7.25 backspace 5x4.75 lugs
front bolt right on with no problems
rears contact the brake hose bolt on the calipers. i just ground the head of the bolt down to about half the thickness it should be. also i had to use a rubber mallet to just slightly bend the metal part of the brake hose down closer to the caliper so the hose did not rub the wheel.
i run drag bags so they keep the rear from squating and hitting the tires. atleast with the 275 40 17's. i havent launched the car yet to see what it does with these. but my shock is in factory location and fender lip has not been cut off or rolled. they stick out they same as the other tires and are the same heighth so i dont see there being a problem.
