need some advice
need some advice
Thinking about doing this as a setup 2.5 ls6 heads from
Texasspeed and there ms3 cam, then a fast 102 and a nw
102tb. The car is not going to be a dd and my goal is to
Around 450 to the wheels its a m6 car to
I didn't see anything about long tube headers (or a CAI). They'd be necessary to have a chance at that 450. After that plan on a clutch at minimum to hold the power. Stubs, axles and drive shaft would also be on my short list.
I've spent almost double that to make the car solid and reliable as well and maybe I'm near mid 400s. If I'd spent more on heads I could have made more HP but wouldn't have the drive train (clutch, GMM, drive shaft, axle stubs, wider wheels, 3.91 gears) and full suspension.
Thanks for the input guys. I'm Going to do this
Setup when I get back from afganland.
Batboy do you have any experience with SRE
In wichita? That's where I was planning on getting
a dyno tune
a dyno tune
If you plan on boosting later, you should definitely factor that into your current build. For example, shooting for 450+rwhp now (naturally aspirated) will require a cam that probably wouldn't pair well with FI later. Do you plan on starting over with a new build when you go FI?
