My 06 build
My 06 build
so I picked up a 06 tr gto with 89,000 miles on it for $10,000 in November. I decide to do a na build on it over the winter goal was to make 500whp on the stock ls2 bottom end. The car will be getting dyno around April 15th
here the mod list
Top end
tfs 225 heads
btr stage 4 na cam
fast 102 port by Tony Mamo
nw 102 tb
duspeed otr intake with ls7 slot maf
morel link bar lifter
btr rocker upgrade
exhaust
kooks step headers (1 3/4 to 1 7/8)
kooks off road pipe
corsa sport cat-back
drivetrain
monster stage 3 clutch with al flywheel
tick master cylinder
mgw-p
one piece drivershaft
fuel
60's injector
walbro 255lp
other parts
hsm spark plug boots
hsm plug wires
hsm engine mounts
c7r timing chain
arp studs
tr55 plugs
power 25% under drive pulley
What do you guys think she will make on the butt dyno
here the mod list
Top end
tfs 225 heads
btr stage 4 na cam
nw 102 tb
btr rocker upgrade
exhaust
kooks off road pipe
drivetrain
mgw-p
fuel
60's injector
walbro 255lp
other parts
hsm plug wires
hsm engine mounts
c7r timing chain
arp studs
tr55 plugs
It will be right at 500, if not a little over with those heads and tooleys cam. We just got done with an c5 ls2 with these exact heads and a lg cam and it made 524 to the wheels. I know the parasitic losses are going to be different, but you will not be disappointed .
Do you remember what the tq was by chance? Nice numbers on the c5!
If the heads were untouched first I'd guess you to be around 60-61-ish cc with .020" off. I'd get them measured though first so you know for sure where your starting from. I'd also get some Cometic .040" head gaskets and factor that into what compression you're shooting for. They will bump compression and give a better quench. The cam maker should have a target compression based off of its overlap that you can get from them.
