need to make gto lighter
hey i was wonderin if there is any non essential **** on my gto i can take off to make it lighter besides the skid plate under the engine?? (that is actually worth it)
you can loose significant weight unless you do major weight reduction...just the basic's and you might get 100 total lbs out of it but not much more. remove the front sway bar for track use but put it back on ASAP cause your handleing goes out the window when you take it off.
Originally Posted by spd98
The brace on the bottom of the spare tire well. as well as the cage around the fuel tank if your really looking to shave pounds.
here's what i've done....
- pulled y-brace (-13 pounds)
- pulled jack/spare (-30 or 35 pounds)
- lightweight holden skidplate (-12 pounds)
- longtubes in place of manifolds (-10 or 15 pounds or)
- boyd wheels (-30 pounds total)
I've saved a shade under 100 pounds so far.
Originally Posted by gametech
If you really want to shave weight, replace all the glass with lexan/polycarbonate. Also maybe switch the steel hood to carbon fiber. Also, ditch the mufflers and resonators for straight pipe. The pipe will weigh less.
I don't think i'd do that on a streetcar.....
I wouldn't go to that extreme either, but the guy did ask how to get rid of weight. There aren't a lot of good options on the gto, without gutting it beyond streetability.
well....true enough....
If you don't miss the rear seats, a seat delete will chop out another 40 or 50 pounds (with the belts)
I'll probably do that sooner or later...nobody sits in the back of my car.
plastic is just as light as the carbon stuff in most cases. also I'm not sure you'll shave alot on these cars with a hood swap. Really and truly if your wanting to really cut it the front seats are very heavy.
http://www.exoticperformanceplus.com....html?item=834
This battery will remove weight, as it is considerably lighter. Taking weight off the front end really helps finding traction for the rear tires. Bob
