Little Eye Candy. Single and Double Apillar Pods
Well here is almost 2 completed Pillar I have been working on.
1. single pillar
2. double pillar
Only thing left to do is cut the hole and make sure there is enough room to compensate for the material in the hole so there will be a perfect seal.
Few pics I got yesterday
Should have them all done today
1. single pillar
2. double pillar
60MM for the eboost and (2) 2 1/16 holes So it will be a triple pillar and prob one of the hardest but it can be done.
Yeah they make a dual 60MM pod. That would be a cool and interesting setup. Dual 60MM holes one for eboost2 other for wideband and a 2 1/16 hole for eletric fuel pressure
Some people wanted to see some installed pics.
Here is the installed triple I did on my car with gauges.
http://www.powertvonline.com/user_vi...l.php?mId=1521
about the 30sec mark you will see them.
Looking good. You do a really nice job rapping the pillar as well.
Here is what I made. Laying the material on these was to much of a pain so I FLOCKED it. I ended up FLOCKING the A&B pillars to match.
Here is some inprocess pics of the last pod I did and let me tell you it was quite a task. Dual 60MM pods. This are really hard to work with and I will be holding off doing any more of those due to the fact we have to get the wrapping down a as there is a stich that runs down the outside radius of the pod but its not visable once installed. 52MM is not a issue at all as you can see
Tim, thanks for doing the dual 60mm for my car. Can't wait to get it in.
You can see readily how involved this one was for wrapping. As soon as Mike gets it in the car, I'll shoot the stock pillar back. Thanks again for taking the time for a truly custom order.
-Ronnie
-Ronnie
