fbody rims on a GTO
fbody rims on a GTO
has any 1 seen pics or put ZR1 rims on a GTO or any other kind of fbody rim and does it look good also if you have some pics can you post them
they don't fit "correctly"
they are a different bolt pattern
and any wheel/tire shop that cares about there customers won't put them on for you
that being said,
many people have done F-Body wheels (and most had little/no issues)
go to the gto site for gto pix,
LS2GTO.com
that being said,
LS2GTO.com
No hubrings, but I used a 5mm spacer. They fit almost perfectly. But the use of spacers does require a stronger and longer wheel stud. (found out tha hard way) I use these as drag wheels with M/T drag radials.
The actually started to bend over from the tourqe load during luanch at the drag strip. All the tourqe load was on just the studs, and not on thecenter of the hub anymore. Not saying that needs to be. But adding a spacer which allose the wheel to slip on the spacer, and the spacer to slip on the rotor, and then the rotor a little slip on the hub. Well, it adds up to 3-4 planes that can slip under tourqe load. Putting in both longer wheel studs, and better lugs will take that all out. No problems now with the same spacers and wheels.
