stock head unit
You start by lifting up the center arm rest, pull up on the piece that meets where the arm shuts. There are clips that go along both sides up to the dash. Also take out the screw that is in the cubby hole in front of the shifter. Then remove screws and there you go.
I saved that thread when it 1st came out.
It is very informative and should answer most of the OPs questions.
also check out:
Big Stereo/Electronics "How To"
http://www.ls1gto.com/forums/showthread.php?t=8498
also check out:
