RPS Clutches?
RPS Clutches?
Does anybody have an RPS clutch?
I have one in my new GTO
and have some questions about whether the throwout bearing needs a shim?
Any sponsors sell them? I need some tech help
Alex, I just logged on late. Will you be around tomorrow?
I'm going to throw a 0.187" shim behind the slave this weekend, I think that sure cure my issues with the clutch not fully disengaging.
Sort of a pain when RPS says for a fix, "well just buy our new $2400 twin disk, much easier on the pedal!"
My 2900 series is new (only a few thousand on it) and this is the feedback I get
TEXTRILIA NEXT TIME
I've got the twin friction and already had to replace the disk and release bearing. The factory clutch lasted longer. They said it was "normal"... I don't think so. I'm going a different route next time.
If that is the case then I will just go with the bird of prey clutch
i dont do installs much, so i personally don't. Mike the Shop Manager and Ryne the owner might have come across it before and be able to get you sorted out.
