6.0 LS2 short block
6.0 LS2 short block
Category: Accessories
Price: $2350
Location (State): MO
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
NEW bearings, rings, oil pump, timing chain. I machine honed it just lightly enough to remain within manufacturer service limits per the OE service manual so that I could re-ring the stock pistons. The crank has had the rod journals ground .010" and the mains are still standard. The main journals have been micropolished.
Professionally re-assembled. Ring gaps are .022" Top and Second. Main oil clearance is .0018"-.0022". The rod oil clearance is .0022"
It is ready to run, or you can pull the camshaft and put something else in.
Comes with a 98--02 F-Body oil pan, windage tray, and pick up tube.
*Can swap stock cam and 4X timing chain for a lightly used, mild Comp Cams turbo cam from BTR (.227/.227 .575" 115lsa), NEW Comp Cams stock replacement lifters and a NIB 1x single roller billet roller timing chain for 300.00 extra
I also have NIB Felpro head bolts, and a NEW Felpro complete gasket set.
2350.00 picked up, will ship at buyer's expense. Paypal accepted, but buyer pays fees. Can meet within 150 miles of St. Louis if deposit received.
Serious only,
Contact
314-four-five-two-66-three-nine
