Sold 1999 Trans Am 441 RWHP N/A Sold
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $9000
Mileage: 73000
Location (State): MI
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
This car is in great shape for the age. Body mileage is a tick over 73,000. Motor was built around 60,000. Everything is in proper working condition. The body is straight but shows signs of age. Some small rock chips and door dents are present as well as a little rash on the bottom of of the front fascia. The rear spoiler has spidering in one spot roughly 3 inches long. The interior has the typical door plastics crack. The sun visors also show the typical wear. The previous owner installed window tint which is also showing a bit of age. Still works but has a few bubbles as well as a little curling at one edge on the passenger window. The pullies under the hood squeek a bit too.
Now, with the bad out of the way, on to the good. This thing hauls. 441hp and 404tq at the wheels. Motor was built to take a decent nitrous shot but was never installed. As is it's all I could want on the road. The Moser 9" takes the extra power (and is built to take more if you do go nitrous). With the BMR torque arm traction is great.
I bought the car at 66,000 miles and have put 7,000 on since in 4 years. I simply don't get out and drive it. The fiancé wants fewer cars in the drive (daily sits out, TA is garaged). Not in a huge rush to sell, I have heated winter storage available at a friends if it stays. It's been stored there the last 4 years and another would be ok. Asking Sold Sold$9,000 Sold Sold or reasonable offer. Any additional pics/info let me know. Work was all done under previous owner at AntivenomEFI in Florida.
https://m.imgur.com/a/Mrhj0
https://m.imgur.com/a/LbrLf
https://m.imgur.com/a/16QXz
https://m.imgur.com/a/tzbAt
Engine/Performance:
LS1 bored to 3.905” and block was decked, line bore checked to spec
Diamond Racing forged -2cc relief pistons
JE Pro Seal Rings
Callie Compstar LS1 forged rods
Calico coated ACL main and rod bearings
Melling Oil pump
LS2 timing set
Comp Cams Hardened pushrods
ARP main studs and side caps
New cam bearings
Polyurethane motor and transmission mounts
All new GM gaskets
GM MLS head gaskets
LS6 Stage 3 heads flowing @ 310CFM
~11.5:1 CR
Harland Sharp LS1 rockers
Comp Cams hardened push rods
Custom grind cam Stage 3R 234/240 113LSA
LS6 Intake Manifold
LS1 ported and polished throttle body
42# Delphi injectors
Racetronix fuel pump with upgraded hotwire kit
Powermaster 200 AMP alternator
Antivenom tune
Pacesetter LT headers
Pacesetter off-road Y pipe with an electric cut out after the Y. (cutout is welded on the factory muffler pipe that connects to the Y. (dyno graphs show it closed/quiet (397rwhp) and open/loud (441rwhp).
Driveline:
Textralia OZ700 Z Grip clutch
Moser 9” Tru-trac, 28-spline moser axles, 3.70 gearing
Short stick w/ OEM Hurst shifter
PST Strip Aluminum driveshaft
BMR Extreme adjustable torque arm
Drilled/slotted rotors with EBC ceramic brakes
