2010 Camaro SS turbo FS/FT
Year: 2010
Make: Chevrolet
Model: Camaro
Price: $25500
Mileage: 29500
Location (State): TX
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
No longer for sale
2010 Camaro SS 2SS
29500 MILES (will increase with being driven)
BLACK
STOCK BLOCK
ECS LINE LOCK
ECS BIG BLOWER CAM / MELLING HIGH VOLUME OIL PUMP / C5R TIMING CHAIN
SDPC .660 SPRING KIT
HURON SPEED SINGLE KIT W/ COMP 83/81 1.15 AR / CERAMIC COATED HOTSIDE AND WRAPPED WITH DEI TITANIUM WRAP / TEXTURED BRONZE POWDERCOATED COLD SIDE / HEAT PROTECTION ON JUST ABOUT EVERYTHING
BORLA CATBACK
PFADT LOWERING SPRINGS / SPORT SWAY BARS / LOWER CONTROL ARM BUSHING KIT / HD ENDLINK SYSTEM / ADJUSTABLE REAR TIE ROD SET / TRAILING ARM BUSHING KIT
DSS 9IN REAR CONVERSION KIT W/3.70 GEARS
ZR1 TWIN DISC CLUTCH WITH MONSTER BEARING SUPPORT UPGRADE AND TICK SPEED BLEEDER
ALKYCONTROL METH KIT (NOT COMPLETELY INSTALLED AS I HAD TO REMOVE FOR THE TURBO KIT, ALL WIRING IS THERE WOULD JUST HAVE TO REWORK WHERE THE TANK/PUMP WOULD BE LOCATED)
LPE TWIN PUMP SETUP WITH FPCM
AEM WIDEBAND/BOOST 2IN1 GAUGE IN SLP POD
HURST SHIFTER
HERITAGE GRILL
DOVETAIL SPOILER
1LE FRONT SPLITTER
ZL1 ROCKER PANELS
HAVE A 1LE REAR DIFFUSER NOT INSTALLED THAT WILL BE INCLUDED
LLOYD MATS
STOCK CHROME SS WHEELS
Just finished Powertour 2016 in this car and had no issues at all. Been a blast and really enjoyed it just time to get a project started that I have been putting off for a really long time.
Do not have final dyno numbers as I was on a bit of a time crunch we got initial tuning done on the dyno and 9lbs of boost and 6 degrees of timing it made 530/565 and it is on the same boost and 13degrees now with us finishing the tune on the street. If I can I will get it on the dyno to see if we can get final numbers.
Only thing I would add to whoever might buy it would be a oil cooler as I deleted the factory oil cooler on the turbo install with plans to add a aftermarket cooler just ran into time crunch issues to get it done for Powertour.
As I mentioned above I would be interested in trades for a 4th Gen Firebird / DD type vehicle / older classic car.
Thank you
Thanks it was a blast on PowerTour and before the Tour never would have thought that I would even think about selling it right after but some of the people I was with got me wanting to get a project started something fierce.
bump up for the weekend, might also consider trades towards a late 70's-early 80s G-body as well
If I cant find a buyer in a month or so I will most likely start demodding to trade it in on something.
