Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Yard Sale, LS Parts, Engines, 4.3 Parts, Random Parts, F-Body Parts, Wheels
Old 02-22-2015, 06:24 PM
carkrazy1987's Avatar
Default Yard Sale, LS Parts, Engines, 4.3 Parts, Random Parts, F-Body Parts, Wheels
Price: $10000
Location (State): FL
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block
LS Engine?: Fits LS Engine
Take a peak, see if there is anything you like. All parts include shipping unless marked.
LS PARTS
12610141 Valley Cover Gasket - $40
12612350 Oil Pan Gasket, x1 - $29
19207929 Intake Gasket - $23
89060436 Rear Main Seal - $17
89018163 Rear Main Seal - $20
13502903 Pressure Sensor - $45
12633904 Front Cover Gasket, x1 - $19ea
12612045 Valve Cover Gasket, x4 - $16ea
12611384 Oil Pan Cover Gasket, x8 - $3ea
15203889 Oil Pan Cooler Gasket, x7 - $5ea
12587147 Inj Seal Kit - $16
12551933 Seal, x2 - $6ea SOLD
12602541 Seal, x9 - $3ea
12585673 Crank Seal, x2 - $18
15035747 Exhaust Gasket - $13
15077362 Exhaust Gasket, x3 - $12ea
15036012 Exhaust Gasket - $24
12595365 Lifter Retainer, x4 - $7ea
12557840 Balancer Bolt - $4 SOLD
Old 02-22-2015, 06:26 PM
12533587 Intake Gasket - $60
12589016 Cam Retainer Plate - $17 SOLD
12558178 Valley Cover Gasket - $19
89060413 Intake Gasket - $77
12630223 Water Pump Gasket, x1 - $4
12576447 A/C Belt - $20
4.3 V6 PARTS
89017866 4.3l Lower intake gasket set, 1 set - $37
12552362 4.3l Head Gasket, x2 - $18ea
88984265 Plug Wire Set - $113
15759293 Oil Cooler Pipe Seal, x3 - $6
88893989 Oil Filter Housing Gasket - $3
12555771 Rear Main Cover Gasket - $4
89017812 Exhaust Manifold Gasket - $17
10220906 Oil Pan Gasket - $12
17113206 Plenum Gasket -$39
17113215 Plenum Gasket, x4 -$32ea
12552542 Throttle Body Gasket - $12
17113561 Throttle Body Gasket, x2 - $13ea
10168525 Head Bolt, x14 - $2ea
10168527 Head Bolt, x12 - $2ea
12577710 Crank Seal - $13
Old 02-22-2015, 06:27 PM
15105884 Exhaust Gasket - $9
15093974 Exhaust Gasket - $19
92066863 Exhaust Gasket , x2 - $5ea
MISC PARTS
93441558 5.7 Distributor New - $350
19179756 Intake Gasket - $50
12551507 Thermostat Seal - $4
12579229 Belt - $31
88932813 Belt - $28
25171792 Fuel Filter - $12
25776344 Exhaust Gasket - $12
10333578 Exhaust Gasket - $7
88987993 Connector - $34
15306007 Connector - $40
15306069 Connector - $34
08654799 Trans Pan Gasket - $5
K060878 Gates Belt - $25
Felpro 61014 Exhaust Gasket -$6
Felpro 60641 Exhaust Gasket - $6
LARGE PARTS / ENGINES
Engine #1 –
Brand New L77 engine. 6.0L with LS3 heads. engine was installed and filled with fluids, and during install of engine oil cooler, engine coolant quick connect plug was cross threaded in. they tried to remove the plug and straighten it, and the threads were pulled out. they tried to seal it unsuccessfully and replaced the engine again. that's when i bought it with intentions of looking for a tap or just welding the coolant plug hole shut. the hole is not needed for any vehicle besides on caprice to my knowledge. This engine is brand new, never fired, just fluids added. still has 8 qts of gm dexos in the pan. and some coolant still in the block.
Engine #2 -
L77 engine, 6.0L with ls3 heads. ~40k miles, i have personally heard this engine run, engine has been torn down, has worn camshaft and lifters, cam bearings may need replacing.
Engine #3 –
L92 Bare Block, Had hole in side of block, was welded shut and new sleeve installed in cylinder #8. Block sat on bench for a couple weeks then cracked by the 4th main. can be welded again, or used as mock up block. Asking $300 plus shipping
4L65E 4WD Rebuild Never Installed, No Converter, H3 Bell Housing - $800 obo plus shipping
LS3 Stock Clutch 10k mi - $250 obo plus shipping
I have more, will post up when I dig out. I have ls engine hard parts also like, rods, cranks, misc cams, front covers, rear cover, valve covers, valley covers, oil pans. Just ask and I will look and see what I have.
Old 02-26-2015, 10:09 AM
Wheels.
6 c5 repro wheels from oem wheels. 2x 17x9.5, 2x 18x10.5, 2x 18x9.5. The 17x9 and 18x10.5 have bfg kdw street tires 60% tread left on em. P275/40zr17 front, 295/35zr18 rear. One front wheel has slight nick, but other wise all perfect. 18x9.5 have hoosier a6 slicks 275/35zr18, about 20 passes on em and also an extra 2 more slicks with 2 passes on em. $900 obo plus shipping
2011 bmw 335i wheels 18in clean, no rash or damage. $400 plus shipping
2011 gmc 2500hd wheels 18 in, factory take offs. Clean no damage. $400 plus shipping
Old 02-26-2015, 12:58 PM
NIKDSC5's Avatar
Good god with the pictures! PM sent
Old 02-27-2015, 08:37 AM
NIKDSC5's Avatar
Money sent on gaskets we talked about, and cam retainer plate! Thanks! Free bump for ya!
Old 03-04-2015, 11:36 PM
5.3truck's Avatar
Pm sent
Old 03-14-2015, 07:01 PM
watabeast's Avatar
pm sent
Old 03-29-2015, 08:27 PM
one fast zo6's Avatar
bump for some deals
Old 06-18-2015, 09:59 AM
5.3 out of a 07 sierra, 85k long block. $750 obo +shipping.
Old 06-21-2015, 10:49 AM
twisted00ss's Avatar
Interested in some body parts and misc stuff
Old 06-21-2015, 12:47 PM
Majestic9C1's Avatar
what kinda deal can you give me on the LS oil pan and front timing cover gaskets shipped to 45014?
Old 07-04-2015, 08:15 PM
qnitro's Avatar
Do you have 2 Valley cover gaskets?
Old 07-05-2015, 12:15 AM
Depending on which ones u need i may have em. Dod? Gen 3 or gen 4.
Old 10-03-2015, 05:54 PM
bump, price update
Old 11-05-2015, 05:53 PM
bump ttt
Old 11-12-2015, 05:27 AM
flyin's Avatar
PM sent
Old 11-14-2015, 12:35 AM
ls7c-10's Avatar
I'll take the 5.3 as long as shipping isn't too crazy. Going to a business 92020.
Old 11-14-2015, 10:32 AM
im showing about $220 for shipping and it says 6-12 business days.
Quick Reply: Yard Sale, LS Parts, Engines, 4.3 Parts, Random Parts, F-Body Parts, Wheels
