Turbo Car Part Out w/ Trailer (Tons of Race Parts)
Category: Accessories
Price: $1
Location (State): MI
Item Condition: Used
LS Engine?: Fits LS Engine
- Engine: $8000
408 LS 6.0 iron block
ARP main studs
ARP cap screw head bolts
cosmetic Head Gaskets
Moroso deep sump pan with turbo fittings and remote oil filter
Eagle cranks shaft
Eagle rods
Ross -22 Pistons 9.5:1 compression
Upgraded rod bolts, the ones just under the 2000's
Ross tapered tool steel pins
Block was sonic checked
Rotating assembly balanced
Block was decked to insure squareness
Virginia Speed VS-3 cam
Virginia Speed push rods
Valve springs from Virginia Speed for that cam
LS7 lifters
Double roller timing chain set
98 lb injectors installed with billet fuel rails
Melling high volume pump with high pressure spring installed
LS3 heads with SS intake and exhaust valves
Stock rocker arms
Holley Modular High Ram intake with Fast 92 throttle body
SFI approved balancer and flywheel with ARP bolts on both
Heads hand ported and flow matched to equal intake by Kerry Laminack at Midland Automotive.
Engine originally built by Kerry Laminack
Engine price includes all accessories and ready to run. Will think about splitting engine if it doesn’t sell.
- Rear end:$2600
Moser 9" 40 spline big bearing housing with spool
3.90 gear ratio
Rear end is 3" narrowed on both sides, 6" narrowed total
Back strap
- Also have Billet Specialties wheels for this rear with MT slicks end but the car needs to be mini-tubbed (will be in addition to cost of rear end) 15x12 - $800
- Almost new rack and pinion - $125
- Adjustable panhard rod - $135
- Willwood front brakes - $500
- Wilwood rear brakes with parking brake - $500
- Spohn adjustable lower control arms - $125
- BMR adjustable torque arm w/ center weld on support - $400
- BMR turbo engine cradle modified for solid motor mounts - $400
- Griffin 4 core engine radiator w/ custom fans (bigger than normal for LS1 Fbody cars - $300
- Front mount intercooler - $450
- Forced Inductions GT-4788 front mount turbo with their smallest T6 turbine housing installed (Just got back from Forced Inductions Never Ran) - $1400
- Turbo Smart waste gate - $300 and blow off valve - $250
- Entire turbo kit, hot side, cold side, FI brand new GT4788, Turbosmart BOV and Wastegate, A2A, turbo blanket and dei wrap for hot side and - $3500
- Dual in tank Walboro 255 high flow fuel pumps w/ lines and fuel pressure regulator - $450
- Davis bump box - $250 SOLD
- Big Stuff 3 fuel injection system with harness and trans controller - $1500
- 3 Sets of Fuel Injection Connection 210# injectors Brand New LS2 Style - $350 per set - SOLD
- Mike Moran 500# injectors New - $1600 SOLD
- E Boost2 Boost controller - $225 SOLD
- Rear mounted battery setup - $175
- Kirkey Seats (one 16”, two 17” and one 18”) have 2 Fbody seat brackets and 4 covers – Seats $100 each, brackets $60 for the pair, Covers $50 each SOLD
- Pair of brand new 5 pt harnesses (out of date, need re-cert) - $100
- Ton of misc Firebird / TransAm interior and exterior parts including taillights, headlights, center counsels, just about anything in the interior or exterior. Ask and I will see if I have what you need.
- 5in VFN sloped WS6 liftoff hood extended to windshield with Zeus rail and fasteners (Brand New) - $400
- Eibach rear lowering springs (brand new) - $50
- BMR rear lowering springs (brand new) - $50
- QA1 adjustable rear coilovers - $350 each set
• Kenwood DVD screen with Nav - $400
• 2 JL Audio amps, 2 channel and 4 channel (custom mounted in trunk) - $400
• 2 Pair Boston Accoustics Mids and Tweets - $400
• 2 12” JL Audio subs in floor of back seat (all custom) - $400
• Lightning capacitor - $50
• Alpine remote paging alarm - $200
• 11 Autometer Nexus gauges in custom made setup - Price negotiable for individual gauges (ask for pictures) with color changing control - $1400 for the entire set
• 2 RJS Window nets - (1 brand new $30, 1 lighted used $20)
• Brand new Autometer Cobalt 5" Tach with shiftlight - $160 Shipped
• 3 sets of fog lights - $30 each set
• A4 center counsel shifter insert in gray with custom mounted gauges - $100
• Stock trans crossmember - $30
• Almost new stock front and rear calipers - $100
• Brand new rear slotted rotors - $60
• 2 pair stock spindles with wheel bearings - $50 per pair
• 2 stock fan setups - $90 each
• Stock radiator with cap and hoses - $50
• 2 pair of stock rear coils - $20 each pair
• 2 stock steering shafts - $20 each
• 4 gas tanks straps - $20 per pair
• MWC wheelie bars - $300
• Lingenfelter 58 to 24 tooth conversion module (only will work on F-body)- $170
• Rear plastics with speaker covers - $50
• Power window and lock switch - $20
• TCS switch - $20
• Camaro SS center air vent radio bezel - $30
• Stock rear sway bar - $25
• Passenger side headlight bracket - $20
• Hoodlatch and other front mounting pieces - $40
• Starter (only on car for 200 miles since new - $75
• Stock air dam - $25
• Windshield wiper cowl - $25
• Customer passenger side A/C compressor with black powder coated
• Earl’s stainless brake lines (only rear center and outers brand new) - $40
• A4 shift **** - $15
• 2 sets of OEM front turn signals - $40
- 2 center counsels Gray - $75 each
All prices will have to add shipping. For no paypal fees you must send as a friends payment. Please text me at 313-790-5592 for pictures or questions. I will be out of town from Feb 19 - 29 so please contact my buddy where the car is currently located at 313-520-4726. HIs name is Frank but nothing will be shipped until after I get back.
radiator
Can you tell me a part number on the griffin radiator and fans
thanks
rich
UOTE=kwik_ls1;19144256]I have up for sale my almost finished Firebird Turbo car with a built 408, built 4L80E with a brake, narrowed 9in with 40 spline axles and a spool, Wilwood brakes all around, David bump box, BS3, Kirkey seats, VFN hood, mini tubbed with full suspension but does not have tubular A arms, meth injection, custom built turbo kit from truck manifolds, GT4788 with BOV and 50mm wastegate, Eboost2 boost controller and plenty more. I am asking $22,000 for the car, extra parts and a 2009 Cargo Mate 24ft + 2ft V-nose enclosed trailer extra tall with all new Carlysle tire, spare, and anti-sway kit. The trailer is a Texas trailer with no winters. If nobody wants the package, I will part out per the following below. The price for the fully assembled engine is $8500. The engine only has about 500 street miles on it. I am asking $3500 for the entire turbo kit. I would sell the roller without any of the drivetrain for $5000. Also I will sell the trailer alone for $3500 and it is in excellent condition. Text me for pictures and individual prices. I do not get PM notifications on here so please text me or call me and if I do not answer leave me a voicemail. 313-790-5592. Tony
- Engine: $8500
ARP main studs
Eagle cranks shaft
Eagle rods
LS7 lifters
Stock rocker arms
- Rear end:$2800
3.90 gear ratio
Back strap
- Willwood front brakes - $600
- Wilwood rear brakes with parking brake - $600
- Spohn adjustable lower control arms - $140
- Entire turbo kit, hot side, cold side, FI brand new GT4788, Turbosmart BOV and Wastegate, A2A, turbo blanket and dei wrap for hot side and Eboost 2 - $3500
10 point Chromoly cage with swing out door bars, plus rocker bars and X bars in rear
- Pair of brand new 5 pt harnesses (out of date, need re-cert) - $120
- QA1 adjustable rear coilovers (2 sets) - $350 each set
• TCS switch - $20
[/QUOTE]
thanks
rich
- Engine: $8500
ARP main studs
Eagle cranks shaft
Eagle rods
LS7 lifters
Stock rocker arms
- Rear end:$2800
3.90 gear ratio
Back strap
• TCS switch - $20
[/QUOTE]
LS1Tech Premium Sponsor
Man, I need that hood. Shipping to FL would probably wreck me though
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
