Complete FiTech fuel injection/induction/ignition setup
Category: Engine - Intake/Fuel
Price: $950
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): MI
Item Condition: Brand New
LS Engine?: Fits LS Engine
FiTech 600hp Power Adder kit which is a bolt on fuel injection system. Very easy to setup and use. My review of the system and video of the setup for sale can be found here
This unit can be ran NA or with nitrous/turbo/blower. It has a built in MAP sensor allowing fueling changes in boost, as well as an independent nitrous control system. Comes with everything it would have come with new ready to hook up. The unit is under warranty until the end of June 2017, but I have never had a single issue with it, great product as you will see in the review. $925 Shipped. SOLD
Next in the package is a perfect condition MSD 6010 which is used for ignition control since the FiTech only controls timing if equipped with a distributor. Comes with rubber standoffs/hardware for mounting, all 6 timing pills, and wiring harness. The only change I made to the harness was cutting the separate 2 wire connector containing 2-Step (low RPM rev limit) and Switch Retard (nitrous) so i could hard wire them in however the connector is included and can be reconnected with the purchase of two terminals if you choose. $260 OBO Shipped
Also included is the Edlebrock Performer Dual Plane intake. It comes with carb studs, PCV elbow, 1 bar MAP sensor (2 bar also available) and throttle bracket. $250 shipped OBO
Also included in the package with be miscellaneous items needed to get running such as Fan Relay and pigtail, Lokar throttle cable, and spring loaded throttle bracket. I can also throw in a drop base air cleaner that has been trimmed to fit over feed/return lines on throttle body unit if you need it.
Literally the only thing you would need to get this up and running on a long block LS is a fuel system. I personally used a FiTech 255lph kit when I had the car in NA trim and it was only $245 and included all hoses, fittings, filters, and pump and worked well.
https://www.summitracing.com/parts/fif-40005
I removed this setup because I am going to try E85 with factory style port fuel injection, everything in this package is in perfect working order. I am asking $1600 for the package. PM me or post below in the comments if you have any questions. I am going to try and sell as a package deal for a week or so before splitting it up, but if you are interested in just part of it let me know and ill get back to you if im going to split.
Payments accepted will be Paypal (F&F or +3%) or Money Order. Thanks for viewing.
