Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Selling all my parts- built lt1 t56, full bmr, tons of LS stuff, QTP LS headers, etc
Old 04-09-2015, 12:57 PM
carguyshu's Avatar
Default Selling all my parts- auburn HP diff, car bra, Lingenfelter 58x-24x, etc
Category: Accessories
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): KS
Item Condition: Brand New
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
I have decided to sell my 99 Firehawk with 42k on it & no longer have a need for a giant mountain of parts. The plan was to put many of them on this car, but I've decided the car is too nice/rare and needs to be sold stock.
I have pics of nearly every part & will try to upload them to this thread when I get time. If you want a pic of a specific part just PM me your email. Most items are located in Topeka, KS, but some are at my home in Lawrence, KS. I frequently go to the Lake of the Ozarks in Missouri & could arrange a meetup in KC or any other place along the route there if anyone wants to buy something local.
LT1 t56 crossmember- $50
Lingenfelter 58x - 24x conversion box, (this needed to drop an LS3 in a 4th gen and keep the stock computer. I clearly never used it)- $250
Black sunvisor brackets- $30
700r4/4l60e pan- $15
ls1 drivers and passenger firebird /trans am lights with brackets and motor covers- $300
L92 water pump- $60
Auburn HP differential for 10 bolt (this is not the standard auburn diff & it came with my car when I bought it, but was never installed. It appears they are about $500 new)- $375
POR-15 wheel refinish kit, but can be used to clear coat any polished or chrome item (this includes 3 different sanding/polishing tube grits for use with a polisher as well as metal ready etching and Glisten PC clear coat, which is designed to go over any polished metal or chrome and protect it so you don't have to polish it in the future. I bought it and started redoing some wheels so a couple of the tubes have a small amount of the tube grit used, but the metal ready etching and glisten PC clear coat were never opened or used. )- $100
Brand new 93-97 camaro front license plate bracket with chevy emblem- $65
OEM GM #12496767 formula firebird car bra for 1993-2002(new still in original packaging)- $75
L92/LS3- This is out of a Denali with 35k. It has VVT, but not active fuel management. I bought it locally & popped the valve covers and 1 head off to make sure it everything was good. This is the complete motor / engine with no accessories- SOLD
Lt1 to LS1 t56 conversion kit- SOLD
Ls1 bellhousing- SOLD
LS1/t56 wiring harness and ECU- SOLD
Brand new LS7 flywheel, pressure plate, clutch, bolts, clutch adjustment tool, slave & master cylinder, pilot bushing. This should fit any LS motor, not just an LS7- SOLD
Strange dana s60 rear with 3.73, 3 channel ABS, S-track posi, welded LCA lowering brackets, brake backing plates, LS1 rotors/pads/calipers, all brake lines & matching strange chrome moly driveshaft (which was painted black with POR-15). I just put this in the car less than 250 miles ago & changed the break in lube out. I believe the cost for this rear/driveshaft now is $3,285 plus $363 on top of that for backing plates plus whatever the calipers/rotors/pads/brake lines are worth. It is painted with industrial black paint & may take me a couple of weeks to get out. The rear is still under the 1 year strange warranty also. - SOLD
BMR adjustable hammertone black torque arm- SOLD
BMR torque arm relocation cross member for LS1/t56 (new never used & comes with bolts)- SOLD
BMR torque arm relocation cross member for LS1/auto- SOLD
BMR non-adjustable LCA in hammertone black- SOLD
BMR double adjustable panhard bar in hammertone black (has only been on the 250 miles the rear has been in)- SOLD
BMR hammertone black strut tower brace- SOLD
LS3 intake with fuel rail, injectors, cover and bolts (I believe this was a new take off unit)- SOLD
Predator handheld tuner (has ECU tune, tranny tune and can program other things like fan activation temp and speedo for gear change. Should work with just about any GM car & it will be unlocked)- SOLD
map extension harness, knock sensor relocation harness- SOLD
85mm MAF sensor with wiring pigtail- SOLD
SLP MAF sensor (new, still in SLP box)- SOLD
90MM cable driven LS throttle body- SOLD
Reusable ARP head bolts for 2004+ LS motor (still in box)- SOLD
SLP fan switch (new, still in original wrapping)- SOLD
SLP Heavy Duty radiator (has 1-3/8" core vs 15/16" core on the stock LS1, so its like 50% thicker) It has been powerflushed & cleaned. See picture below comparing it to stock. It will work for either an auto or manual.- SOLD
Corvette brake conversion for Lt1 or LS1 4th gen firebird/trans am/camaro (comes with corvette calipers, corvette abutment brackets, and brand new conversion brackets with all hardware and instructions) you'd need to just add the pad/rotor of your choice- SOLD
BMR LCA lowering brackets (bolt in)- SOLD
3" QTP electric exhaust cutout with new y pipe, wiring and all hardware- SOLD
Motive 3.73 gears for factory 10 bolt (these came with my car when I bought it, but they were not installed)- SOLD
TA rear end girdle with bolts- SOLD
3.42 torsion 10 bolt out of LS1 with 25k (no brakes) & it needs the little block put back in the diff (I had to rob it out for another project, but should be easy to put back in)- SOLD
LS coil packs off L92/LS3- SOLD
Auto to manual tranny conversion kit- SOLD
Poly rear sway bar endlinks (red)- SOLD
Spherical rod end double adjustable panhard bar- SOLD
Vigilante 3600 stall (has only been in a couple thousand miles)- SOLD
SVO red top injectors (these run 36# on an LS) I never even took these out of the box. Bought them here on the forum and they were cleaned and flow tested before being sent to me- SOLD
Lt1 line lock (new & still in packaging)- SOLD
Stage 2+ LT1 / small block or big block Chevy T56- I had this transmission rebuilt by a local shop years ago and it has all new upgraded components (steel shift forks, mainshaft, all new gears/synchros/seals/blocker/bearings etc.) Pretty much the only thing reused was the input shaft and tailshaft. I ran it less than a few thousand miles on my old bolt on LT1 car and swapped this tranny out when I sold it thinking I would convert it over to an LS tranny in my new car since I knew I had so much money in upgraded and rebuilding this one. Included with this will be the bellhousing & shift fork (someone locally wanted to buy just the clutch from me) I'm selling this for substantially less than what I have in. - SOLD
LT1 throttle cable cover- SOLD
Stainless LS 1 3/4 QTP headers with high velocity collector for 4th gen- SOLD
LT1 power steering pump, reservoir and lines- SOLD
Old 04-09-2015, 04:43 PM
carguyshu's Avatar
got pics of some of the parts:
L92
LS3 intake with fuel rail, injectors, cover & bolts
poly rear sway bar end links
I think this is an LT1 power steering pump with resevior and lines
radiator
my radiator vs stock LS1 radiator- was flushed and cleaned. Perfect upgrade for a higher output LS motor or someone that just wants a cooler running LS motor. It is a bolt in swap.
firebird/trans am car bra 93-02
firebird/trans am car bra 93-02 never used still in GM box
corvette big brake kit for LS1 or LT1 car
lt1 line lock kit
drivers/passenger headlights for firebird/trans am with bracket
camaro front license bracket- new never used
SLP MAF- new never used
BMR LCA relocation brackets- bolt in
LT1 to LS1 t56 conversion parts- midplate and input shaft
ls1 t56 bellhousing
90mm LS cable driven TB
QTP electric exhaust cutout with brand new Y pipe (hardware is in different pic and is still sealed)
never used ARP head bolts for 2004+ LS motor
handheld programmer
new never opened and still sealed SLP fan switch
l92 water pump
double adjustable sphere rod end panhard bar
3.42 10 bolt torsion rear out of LS car. Block that needs put back in is in bag on top
motive 3.73 10 bolt gears
LS1/t56 harness and computer
exhaust cutout hardware
ls1/t56 torque arm relocation mount. I have all the hardware, but forgot to include it in pic. Never been installed or used.
motive 3.73 instructions
auburn HP diff for 10 bolt
auburn HP diff for 10 bolt - this is about $500 new
QTP stainless headers 1 3/4 with high velocity collectors
lt1 throttle cable cover
lingenfelter 58-24 box, map extension harness, knock sensor relocation harness
coil packs with wiring
POR-15 wheel or any polished or chrome surface refinish and protection kit. I dropped the can and dented it, but cans have never been opened. I kept compound in sealed ziplock after opening it.
Old 04-09-2015, 06:59 PM
carguyshu's Avatar
t/a cover is sold
Old 04-09-2015, 07:55 PM
carguyshu's Avatar
coil packs are sold
Old 04-09-2015, 08:00 PM
carguyshu's Avatar
pending sale on L92/Lingenfelter box/extension harnesses/LS3 intake/90mm TB/ARP head bolts/85mm MAF locally. If the deal falls through these parts will be available individually again. Until then I will only be willing to sell them all as a package deal.
Old 04-10-2015, 04:51 AM
Cole Train's Avatar
want the torque arm
Old 04-10-2015, 04:00 PM
carguyshu's Avatar
pending sale on SLP MAF
Old 04-11-2015, 12:37 AM
carguyshu's Avatar
SLP MAF sold.
Old 04-11-2015, 12:58 AM
carguyshu's Avatar
strange dana s60 & driveshaft sold
Old 04-11-2015, 09:48 AM
camarodude87's Avatar
would you do a package deal on tq arm and relocation bracket for t56?
Old 04-11-2015, 03:20 PM
carguyshu's Avatar
$20 off if you buy both.
Old 04-11-2015, 09:41 PM
Shipping quote to 37042?
Old 04-11-2015, 09:49 PM
carguyshu's Avatar
Buy them both & I'll include shipping, but not the $20 off. My paypal is carguyshu@aol.com. Please send it as 'send money to friend' or a gift from your bank account rather than a credit card as paypal charges a 3% fee otherwise. That or add 3% to the total price when you pay.
Old 04-11-2015, 10:16 PM
Could I get pics of the torque arm? sent to my #
Old 04-11-2015, 10:25 PM
carguyshu's Avatar
pics sent
Old 04-12-2015, 02:54 AM
Diablo666's Avatar
What year one harness?
Old 04-12-2015, 09:52 AM
carguyshu's Avatar
its a wiring harness and CPU for an LS1 and a t56 6 speed years 99-02. It would hook up everything underhood and that goes to the t56.
ls1/t56 bellhousing sold
Old 04-12-2015, 11:14 AM
Diablo666's Avatar
Ok I just water to make sure it wasn't a 98
Old 04-12-2015, 02:26 PM
carguyshu's Avatar
ls1/t56 harness and ECU are sold
Old 04-12-2015, 05:49 PM
Cole Train's Avatar
i believe i've already called the torque arm. he said it wasn't gonna be off the car for couple weeks anyway. I'm not gonna pay for something 2-3 weeks in advance of it coming off a car
Quick Reply: Selling all my parts- built lt1 t56, full bmr, tons of LS stuff, QTP LS headers, etc
