98 Camaro 1000+RWHP for trade or sale. Only owner 16 years
Year: 1998
Make: Chevrolet
Model: Camaro
Price: $22000
Mileage: 100
Location (State): TX
Color: Black
LS Engine?: Car has LS engine
Figured I would float this out here to see if there are any takers. Please do not PM me or post to this thread if you are truly not interested. Trades accepted. Message me or text me at 432-352-6299 or post to the thread for any questions that I have not answered with these photos and specs.
http://i221.photobucket.com/albums/d...826_195801.jpg
click on the vids below to watch start up and driving.
Click on this link below to see all other interior pics. I couldn't post all of this to the thread. No more then 10,000 characters allowed.
http://s221.photobucket.com/user/han...camaro%208-26-14
This video below is a clip of its best time. Tires blew off and I went into the middle lane and stayed in it. This is on a 300 shot on a shitty TNT prep night in shitty air. DA this night was just below 6000. On this tune up on this shot it has a .60 if not a .50. This is a low 5 sec 1/8 mile car on a 500 shot out here in this area. Prob be in the high 4's in better air like Dallas or Houston.
I am making some changes in life and really hate to get rid of this car but there are more important things right now so here she is. I am the only owner of this car and have had it since December of 97. Super clean and fast as ****...never dynoed it but from the numbers its putting up at the track it is a 1000+ RWHP car.
Motor
GM 6.0 Iron Block
Eagle 4” Stroke Crank
12:5/1 Compression ratio
Only used C16 for nitrous tuning purposes
Cali Comp Star H-Beam Connecting Rods
Weisco reverse dome pistons
Total Seal Rings
Half the coolent sleeves filled with hard block
Lifer bushings bored to .904 with morel custom solid roller .904 lifters
Huge Comp Cam Solid Roller @.050 .744/.759 278/296 115LSA
TFS custom heads 245cc with 88cc custom nitrous port, custom bored pushrod ports for larger pushrods.
Triple core PAC spring, closed seat pressure 300lb, open seat pressure 850lb
Custom offset Jesel Shaft mount rockers
1/2 “ manton exhaust pushrods, 7/16” manton intake pushrods
Custom nasty performance heightened valve covers.
Super Victor intake port matched to heads
Intake custom plumbed by Nitrous outlet with 8 direct port fogger nozzles. Currently jetted for 250 shot.
Kooks custom headers 2 1/8" step up to 2 1/4" with 4" collector
Quick fuel 1050 Super Carb
MSD 6010 Ignition system with MSD LS1 coil packs (these coil packs were before all the problems) never had a problem with them and have turned this motor 9k rpms
ARE custom Dry sump oil system
Be Cool quad core radiator
Meizer electric race water pump
Transmission
McIntosh custom Power Glide
Custom 2/1 chrome molley gear set
Hardened bell housing SFI certified
Tranny Shield
PTC 8” Torque converter designed for 500 shot and 700 fly wheel all motor hp
Mark Williams Chrome molley drive shaft
Mosier custom 12 bolt rearend
Hardned rear end cover
4.56 gear ratio
38 spline axles
5/8 wheel studs
Aermotive A100 fuel pump
All braded stell fuel and oil lines
Low pressure aeromitive fuel reg
Two aeromotive fuel filters
5 gallon RCI fuel sump
Suspension
Double adjustable QA1 front and rear shocks
AJE complete front end and kmember, a arms, control arms
Flaming river Manuel Rack
Willwood race brake system with manual brake reservoir
Wolfe Race craft chrome molley, sub frames, lower control arms, panhard rods, torque arm, drive shaft safety loop, power glide crossmember
Tires are the Mickey T 275 radial X class with mickey T 15” front runners
Wolfe Race Craft 15 point full chrome molley cage tig welded and painted
Stroud fire supresent system for inside car and in engine bay
VFN 7” cowl fiber glass hood with zues drivers
Custom gauge instrument panel with all auto meter gauge, RPM, Vacuum, Wide Band, Oil pressure, fuel pressure. EGT
MSD high torque 22:1 comprssion ratio starter
All electronics loomed and wired clean and to inside control panel
2 aluminum kirkey seats with both 5 point harness seat belts.
Think that covers most of it.
This would also include the three 15lb bottles I have too.
price drop
Well I am still needing this thing to go so I am dropping the price to 22k. I am also willing to entertain a trade if you have a camaro or TA F-bod or even an older one. Hit me up and let me know........just want something more streetable.
Bump to the top!!!!!!!
