1997 30th anniversary SS 5.3 swap/PT88 turbo/TH400 swap/QP 9" rear part out
Category: Racing Parts
Price: $1
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird, Front wheel drive vehicles
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6, LT1/LT4, Small Block, Big Block
LS Engine?: Fits LS Engine
1997 30th anniversary SS #404 from SLP
LS 5.3 swap
TH400 swap
Quick Performance fabbed 9" rear
Custom fabbed turbo setup using truck manifolds
Precision PT88 turbo
A close friend of mine has already offered to buy the complete engine for his turbo 5.3 build.
My car made 690 rwhp on this setup on 14lbs. We tuned it on 21 lbs at one point as well but hasn't really be ran there. If I do part this out I want to sell as much of the Large stuff first before I pick the car apart. At this point I just want to see who would be interested in what and if I get a good offer I will start the tear down. These are the following "big parts" to start with.
Complete th400 swap (for LT1 or LS1)
ProTorque 4000 stall (footbrake to 3200)
B&m megashifter with factory center console cut to fit boot
Spohn custom 3" driveshaft for TH400 to 9" or 12 bolt.
Short tail TH400 with new cheetah FMVB
34 element Sprague and alto clutches
SFI LS flexplate with adapter for converter
M6 crossmember with poly bushing and spacers.
Summit deep pan
Price on this entire swap with everything listed is $2200
Quick performance 9" fabbed rear
Housing has around 3k miles on it but over this winter I re did the entire rear with all new seals and bearings for a gear swap for the turbo setup. Current gears are 3.25 but will send it with a set of 3.89 as well. No noise whatsoever. Very smooth.
Strange center section
Motive 3.25 gears
Mosier 35 spline axles
1/2x20 extended studs
LS1 brake setup
1350 yoke
Detroit locker
No ABS/TC
Rear is fully adjustable in 3 different places for pinion angle w/torque arm support. This rear end is a bolt in replacement for any 93-02 f body.
Price for entire rear end setup with everything listed. $2250
Turbo setup
Truck manifolds w/crossover to center
T4 flange
Tial 44mm wastegate w/5,7,11 and 13lb springs
Entire hotside wrapped in DEI heat wrap
Coldside is 3" mandrel pipe w/no unnecessary joints.
EMUSA big front mount intercooler
All Coldside piping has been powder coated white to match the car.
Tial Q 50mm BOV
Bung for IAT
Metal screw in IAT
For this setup you must delete a/c, stand radiator vertical, move battery to the rear of the car
Also will come with a Hallman pro MBC
Downpipe is 4" and I have made a custom motor mount to fit this through the stock K-member. Merge piping has bugs for O2 sensors and downpipe has Bung 12" from turbo for wideband.
Can't send detailed pictures of setup. This setup will make huge power. Is capable of well over 1k rwhp
Price on entire turbo setup with everything listed will be $3500 and I will send the turbo in to my guy in Arkansas to be looked over before sale to make sure it is perfect. This will be a bolt in setup. Everything needed. And for a bit more I can include the battery relocation setup and the vertices radiator setup with the Spal pushers.
Wheels & tires
Brand new over the winter. Dyno time only. Zero street miles
17x7 Racestars up front with brand new tires
15x10 racestars out back with 325 50 r15 hoosier Drag radials (brand new)
$1200
Fuel system
Magnafuel 750 pro tuner with -12 magnafuel pre filter and -10 magnafuel post filter. Stock fuel tank that I have sumped.
Frozen boost -12 stainless braided line from tank to pre filter.
Frozen boost -10 stainless braided line from post filter to fuel rail
Crossover in rear
-10 line from rail to Holley FPR mounted on front of shock tower
-10 return line back to top of factory tank.
Factory tank has stock sending unit in it so fuel gauge still works
5/8 red anodized fuel rails that I have made brackets to work with LS2 intake manifold
FIC 127lb high impedance injectors
Will sell entire fuel system with everything list Including tank for $1750
Other big items I will sell will be the brand new black and white houndstooth 30th anniversary seats. Less than 1 yr old. Front and rear in absolutely perfect shape. $1250
Original 30th SS SLP hood.
You can buy aftermarket all day but if you want original equipment you know that for a 96 or 97 SS..............well, you can't buy this hood. They don't produce it anymore. There are none left. Paint has a bit of cracking. But overall hood is in good shape. And yes, it has the "made in canada" stamp underneath which is the identification to show it is original. $2000
Original 30th SS spoiler
Again, so.ething that you can not buy anymore. $500
ECU and Harness out of a 99-02 6 speed f-body. I have completely reworked this harness to match a 96-97 f body with an LS engine. All factory gauges work as well as obd2 port for tuning or reading codes. This is a perfect setup cleaned up with no emissions. Rear o2's deleted. All the "BS" is gone and cleaned up. This will be perfect for someone wanting to swap any LS motor into their 96-97 f body. $450 for the whole setup.
Also for that same person who wants to LS swap their LT1 f body will be all the front suspension out of this car which includes...
Stock LS1 K-member
Stock LS1 rack and pinion out of a 12k mile car
Spindles, drilled and slotted rotors
Also, QA1 coilovers w/spanner wrenches
$600 for entire setup.
Call or text anytime for pictures or more info at 6602336251. Prices do not include shipping or paypal fees. I have a perfect trader rating and if anyone would like to see the car run we can arrange that until I start tearing it down. Also, if someone sees this and is I terested in the entire car in its running driving beastly form then please contact me soon. Price on car is $15k. Also willing to entertain trades like c5 or c6 vettes, other f bodies plus cash, little gas saver plus cash, 87ish grand national, desiel 4x4's. Anything really. Just something easier to sell. I'm doing all this so I can start on my 2010 SS. Thanks for looking.
D.J.
If that hood had never seen the light of day I would maybe consider that price. It in a box, fresh paint and not a spec of dirt having ever touched it, just maybe I would consider it. But 2K and its been in the weather,on the streets,track etc for 18 yrs,,,,,, good luck with that**
Then you are just fine settling with a reproduction. This hood was only on 2500 cars in 96 and a little over 3k in 97. I have seen them go for up to 2500. I promise that there is almost a 0% chance that you will ever find an authentic 96-97 SLP SS hood for sale, let alone cheaper than this. I know some people are always looking for a deal but how much is something worth that you can not find? Not that much to anyone with a 98-02 camaro. But, if I had a 97 SLP SS and my hood got tore up, I sure wouldn't put a reproduction hood on that car. I would pay whatever it cost to have original back on it.
Don't argue with people on stuff like this, it is pointless. At the end of the day it is worth what someone is willing to pay for it. When people come in on a sales thread like this just ask a moderator to delete it. Or start the thread over. This guy ruined it two posts in.
I don't mean to sound like I am arguing and I totally agree with the fact that something is only worth what someone will pay for it. Having said that I want everyone to know I am negotiable on the hood price but just don't try and tell me it's only worth what a reproduction is worth because that is not the case. I may sit on the hood for 10 years if I part the car out but that is one of those parts I feel like is not replaceable if it is damaged but I do want to make it clear that I am negotiable on it!!!! Thanks!!!
9 7 ss part out.
I just want to start off by saying right on with the price of the hood. I recently sold a 97 slp ss that I aquire through a work trade on a customers car and had no interior of hood or wing. I restored it in every way but hood because they were a bitch to find an oe one. So hell yes to you. I Was Wondering where you were located and if you were willing to sell dash and door panels. I've got a 99 ss I'm bringing back from the grave right now with grey interior. Thanks
Decided to keep the car and swap out the trans setup to a glide setup. So my entire th400 swap is up for sale including the B&m megashifter that is bolt in ready for a 4th gen including the upper console with the boot fitted. Text anytime at 6602336251.
