2008 Hummer H2 Supercharged 700hp! Built engine/trans
Year: 2008
Make: Hummer
Model: H2
Price: $36000
Mileage: 85000
Private or Dealer Listing: Dealer Listing
Location (State): MI
Color: Black
Transmission: Automatic
Drivetrain: 4WD & AWD
LS Engine?: Car has LS engine
85000mi
Engine: Built by Motiva Performance, Albequerque, NM
525awhp - estimated 700bhp
3000 miles on the engine
6.2L stroked to 416ci
9.8:1CR
Magnuson Supercharger
ARP Bolts
Manley forged crank
Manley LS Platinum pistons
Manley H-Beam connecting Rods
Platinum spring Titanium Retainer and Pushrods
Cylinder Heads re-done
New GM Water Pump
New Nations High Output Alternator
Kook's headers
Kook's custom y pipe
High flow cats
Borla exhaust
Custom multi core large all aluminum radiator
Twin electric fans 2-stage-electroincaly controlled
Oil catch can, plumbed for easy empty
160 degree thermostat-stat, I would run 180 in winter
K&N cold air intake
See dyno Video
Transmission: Built by Circle D Transmission (Houston, TX)
6L80E Circle D Vehicle bench package
New gaskets, seals and rings
New valve body seal kit
New check *****
New larger inlet filter
New snap ring kit
Increase clutch capacity in 2-6, 3-5-R & 4-5-6 drums
Kolene steels in 2-6, 3-5-R, & 4-5-6 drums
300M billet intermediate shaft & with Reinforced billet output carrier
4140HSTR 4-5-6 clutch hub Reinforced 1-2-3-4, 2-6 & 3-5-R clutch hub
Spiral-lock snap ring in 3-5-R drum
Valve Body & Pump are performance Calibrated to CDT Specs
Set transmission end play to CDT Specs
Performance TCM tune
New Torque Converter
New upgraded Pump
Auxiliary transmission cooler
NOTE: The H2 transmission was built and tuned in house at Circle D
Stock + options that came on H2 (some added):
Color - Black exterior and black interior
Leather seats
Heated driver and passenger seats
Power driver and passenger seats
Cold A/C
Navigation
Sunroof (tilt and full slide)
7 Passenger seating
Bose sound systems (theater surround) with DVD and roof mounted screen
Tilt steering, power windows and locks
Remote start
Ravelco custom system security system, engine immobilizer
BF Goodrich MTR on 35x12.50x20 inch rims
H2 is all wheel drive with electronically locking differential
Automatic Transmission 6L80E
Traction control
Stabilitrack
Roof rack
Rear suspension is coil springs with air bags
Towing brake controller
Front end has been completely gone thru
New bilstein shocks
Includes full set of Pewag snow chains ($1000)
$37500 obo
