1999 Trans-Am 6-Speed 450+HP - $13000
Year: 1999
Make: Pontiac
Model: Trans Am
Price: $13000
Mileage: 37300
Location (State): CT
Color: Blue
Transmission: Manual
Drivetrain: Rear Wheel Drive
Engine is now a LS6 block with upgraded internals (Crank, Pistons, Rods and so on) that were all professionally installed. AFR heads and custom cam. The exhaust consists of Kooks Stainless steel headers to a catted y-pipe and Stainless steel Borla Exhaust Catback that is electronically adjustable. PCM tuned by Slowhawk.
The rear is a Moser 12 bolt with 4.11 gears and upgraded adjustable control arms and upgraded shocks. Springs are stock.
Transmission is fairly stock with some upgraded synchros and only a short throw shifter. The clutch is a SPEC and has very low miles on it.
The in dash player is new with new speakers and subwoofer in back. The hood is an aftermarket Mecham hood (stock hood is not available)
There is more but those are the major things.
The car will come with an additional Mecham wing that's painted to match and 2 spare rear tires mounted on matching wheels if you decide to use them.
Mods list that was asked for by several people below.
(* indicates receipt)
Spohn Weld in Sub Frame connectors *
Moser 12-bolt with 33 spline axels 4.11 gears and Aluminum TA cover
Moser relocation brackets *
Bilstein Shocks*
30lb Fuel Injectors*
ACPT Carbon Fiber Drive shaft *
Below Engine mods are one order*
LS6 GM Block
Diamond Forged Pistons
Diamond File fit rings
ARP Main Stud Kit
Clevite rod\main\cam bearings
Crower Rods
Nitrated Crank
LS6 oil pump
roll master timing chain
AFR 2055cc heads
Hardened pushrods
TTP Equalizer Cam V2
LSX 90MM Fast intake
Nick Williams 90mm Throttle body
Spec Stage 3 clutch*
B&M Ripper shifter
Kooks Stainless Steel long tube headers
Y-pipe with cats
Borla Stainless steel catback with electric cutout opener.
Shift Light
Line lock
re-Tuned by Slowhawk a few years ago
The car has an aftermarket head unit, speakers with sub and amps in the wheel well. All easily removed if you want.
I still have the cars original window sticker as well
This is all I can remember\have receipts for.
oh also have a car cover for it.
Car at Idle Sound clips:
http://47.22.130.68/CutoutClosed.m4a
http://47.22.130.68/Cutoutopen.m4a
Added:Link to video of how car sound. This is at slow hawks getting tuned
http://47.22.130.68/dyno.mov
If video doesn't play you can download here
http://47.22.130.68/dyno.zip
Link to vertical video walk around:
See dyno and more interior pics below
sorry, didn't understand. They are aftermarket rotors and pads.
Here is a link to how the car sounds. This was at slowhawks getting tuned. I will try to upload an idling move by Tuesday.
If video doesn't play you can download here:
All PM's responded to. Including under hood pics and under car (as best I could) and odometer pic.
While looking for things I found the clear plastic firebird front plate cover for those of you who live in an enforced front plate state. you get that too. They were made by a member here a long time ago (coach something). I believe he received a cease and desist from GM lol.
I have been contacted by several people from out of state. If it sells I will update immediately.
Happy Memorial day everyone!!!
Oh, the Strut Tower Brace is around here somewhere.
