Notices
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
1000 hp capable ltx (afr227,F1-R, forged 383)
Old 12-27-2015, 12:15 PM
dropped94formula's Avatar
Default 1000 hp capable ltx (afr227,F1-R, forged 383)
Price: $0
Location (State): MO
Item Condition: Brand New
Engine: LT1/LT4, Small Block
LS Engine?: Non-LS Part
Selling 1000 hp procharged ltx. 7000 complete or will part out. All items are brand new never ran. (over 15k invested) going turbo lsx. And putting money towards our honeymoon coming up. Call or text matt 816 804 8718
$3,500
Full forged 383 (eagle crank, double keyed with hub, compstar 6” h beam rods, diamond pistons -28cc dish) good for 8:1 with 65 cc heads.(arp rod bolts) Splayed 4 bolt main caps (arp studs and bolts) arp head studs. solid roller bullet blower cam Lloyd Elliott spec’d 244/255 dur. 115lsa .623/.623 lift with 1.6 rockers) double roller timing chain. canton oil pan with hv melling oil pump. (bolted pick up) milodan s.s. dipstick tube. Was built for strip/steet and 7500 rpm.
$1000
Jesel shaft mount rockers with comp cam tie bar solid roller lifters. (1.6 int 1.6exh)
$1800
Afr 227 65cc cnc ported heads (flow at .650 lift, 315 cfm int, 233 cfm exh) afr intake gaskets, pushrod guides, an hose and fittings for steam crossover. and fabricated sheetmetal aluminum Valve covers.
$200
Ati super damper, with double keyed crank hub.
$300
Msd igniton billet distributor with igniton pick up pn 2345
$200
Miezere electric water pump and powdercoated housing. (all unused ports welded)
$2700
Procharger F1-R and house of boost blower bracket with cog pulley setup. Fresh rebuild on the f1, impeller in perfect shape. Billet crank, blower, and idler pullies. 50mm gates belt. All hardware. Powder coated brackets.
Last edited by dropped94formula; 01-09-2016 at 10:08 AM. Reason: Price change, post edit.
Old 01-02-2016, 10:22 AM
Still for sale. Made some changes. Intake, rails and alt. Relocation gone.
Old 01-03-2016, 04:01 PM
Bump to top.
Old 01-08-2016, 11:38 AM
tazman71's Avatar
PM sent
Old 01-09-2016, 10:09 AM
Some ignition parts gone.
Old 01-23-2016, 05:43 PM
bornwild's Avatar
Default Electric water pump
PM Sent!
Old 02-07-2016, 09:14 PM
yougotboost's Avatar
Is that your lowest number on heads?
Old 02-20-2016, 10:20 PM
Beastz28's Avatar
Those are the offset rockers specifically for the afr227 heads?
Quick Reply: 1000 hp capable ltx (afr227,F1-R, forged 383)
